Dual Honda 2000s versus AC |
Post Reply | Page <123> |
Author | ||
Luv2Q
Senior Member Joined: 30 Aug 2014 Location: Central TX Online Status: Offline Posts: 309 |
Topic: Dual Honda 2000s versus AC Posted: 31 Jul 2015 at 11:37am |
Thanks, Cliff. Yes, a delay seems plausible. I may have a chat with Progressive & sound them out on this phenomenon. Thx again ..
John & Teri
Tundra 5.7L V8 / RP 180 E2 WDH / Integrated controller (POS) replaced by Tekonsha P3 |
Podamus
Newbie Joined: 29 Jul 2015 Location: Camas WA Online Status: Offline Posts: 6 |
Posted: 31 Jul 2015 at 1:33pm | |
I'll start with saying I know nothing about hard start capacitors. WRT the 5th wheel it could have been the combination of the AC and the inverter. But I'm curious: Do you have two of the 2000i models or the companion. I'm using the companion with the 30A plug.
Jim
Camas WA 2015 RPod 179 2014 Ford F250 |
Luv2Q
Posted: 31 Jul 2015 at 2:20pm | |
Jim, yes, using the Companion w/ 30 amp plug.
John & Teri
Posted: 31 Jul 2015 at 8:40pm | |
You may just need to bypass the surge protector when using the generators. You are far less likely to run into the problems it will protect you against, while using a generator, so I wouldn't call it a compromise on safety.
Luv2Q
Posted: 31 Jul 2015 at 11:45pm | |
Thanks for the suggestion, Doug. With 3600 W continuous & 4k surge capacity, I can't believe the dual Hondas can't keep up. (I say that like I know what I'm talking about. Sorry)
If I'm not mistaken, my EMS-HW30C has a bypass switch (button) on the display module. That would be downright handy. Thx again, Doug & others, for sharing your thoughts & experiences.
John & Teri
Podster
Posted: 01 Aug 2015 at 6:48am | |
John, I think the surge protector is very sensitive and its just detecting a little bump. It's not your generators. Since you know the power source is good I think its ok to bypass.
I'm sure its just a momentary drop. Does the EMS cut the power or just throw a code? Bypass switch: This switch is located on the remote panel, and allows the user to bypass the computer circuit in the EMS in the event of computer failure, thus allowing source power into the RV. This does not disable the surge protection portion of the EMS. |
Cliff & Raelynn
Luv2Q
Posted: 01 Aug 2015 at 2:29pm | |
Cliff, I think you're right. Everything points to a sensitive EMS reacting to a miniscule fluctuation in power. And, yes, it cuts the power.
I'll give the bypass a try & report back. I can use the Kil-A-Wat to monitor for dangerously low voltage while conducting my little "experiment".
John & Teri
Posted: 01 Aug 2015 at 3:28pm | |
I agree it is probably just detecting a momentary blip and not reflecting the voltage 99% of the time.
Luv2Q
Posted: 07 Aug 2015 at 10:11pm | |
Update ..
Quick background: Using the PI HW-30 hard-wired EMS, I was using 2 Honda 2000s (regular + Companion) in parallel to run my 13,500 btu ac. When the compressor cycled from Off to On, the EMS threw a low-voltage error code & shut down the power. This was with the Eco throttles on. (No problem with the Eco throttles off & the generators running at higher RPM.) That made no sense to several of us since, in "continuous" mode, have a combined 3600 watts. What seemed likely was that, when the ac cycled on, there was a momentary pause while the two generators spooled up. Possible solution: turn the EMS off thereby bypassing it & trust that the Hondas deliver stable power. The test today showed there is indeed a momentary low-voltage lag, but the generators kept the ac running. I was monitoring the voltage with a Kill-a-Wat and they went like this: 122.1 - compressor on 125.6 - compressor off 102.1 - flashed once when compressor came back on 122.4 - compressor on 125.7 - compressor off 101.1 - flashed once when compressor came back on 122.4 - compressor on Next question: Can the momentary brown-outs cause any damage to ac, fridge, etc.? I really could use some advice here, as I have -0- skills in this area. BTW, why don't I just run it with Eco throttles off? Answer: I may have to, but hope to avoid the extra noise & fuel consumption. Thanks in advance, gents.
John & Teri
Posted: 08 Aug 2015 at 12:47pm | |
It is probably sagging lower than that, you need a special voltmeter to read true spikes and sags. But, I wouldnt worry about it. 108 is the minimum for continuous operation but equipment usually will tolerate lower startup sags. The fridge just runs a heating element on AC so no worry there.
