Changing Out Keder Channel Rails? |
JohnBG
Senior Member Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Topic: Changing Out Keder Channel Rails? Posted: 03 Aug 2015 at 4:26pm |
I have a 2010 RP-171 with the 9mm keder rails. I recently bought a newer r-dome for that works with the newer style 14mm keder rails since I can't find an older dome that works with the smaller keder. I bought new 14mm keder rails from Forest River (had them cut them in half in 8' lengths for shipping) but they do not have mountilg holes drilled in them.
I took a tape measure and measured the distance between the screw holes on the 9mm keder on the camper and they appear to be evenly spaced at 6". I am guessing that if I make some kind of a jig and drill holes in the new 14mm channel at 6" intervals that they might line up. I am kind of stumped on how to curve the keder channel. Do I just start installing on the top flat section and bend it by hand for each hole? Has anyone done this procedure, if so how did you do it?
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
JohnBG
Posted: 04 Aug 2015 at 11:36am |
Wot, no suggestions?
2010 R-Pod RP-171
Posted: 04 Aug 2015 at 8:49pm |
You could call FR and ask them how they bend it. Maybe a standard form/rollers/something for each pod.
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Posted: 06 Aug 2015 at 8:30pm |
I am all for using a torch to help bend it..................but I have been know to break lot of things
jstrenn
Groupie Joined: 14 May 2015 Online Status: Offline Posts: 71 |
Posted: 07 Aug 2015 at 8:28am |
I am thinking if you use the tool that electricians use to bend conduit. That would probably work. They can be purchased at Home Depot or Lowes
https://www.youtube.com/watch?v=zimw9PShuww
Posted: 07 Aug 2015 at 7:52pm |
That might work.
