  New Posts New Posts RSS Feed: water pump
Topic Closedwater pump
SNO4ME View Drop Down
Direct Link To This Post Topic: water pump
    Posted: 26 Aug 2015 at 9:50pm
Originally posted by GLBCamper
Is the hot water heater filled simple by connecting to city water, or do I need to do something else? How can I tell if it's full before turning it on, so I don't burn it out?
You need to bleed the air out of the water heater. Open your hot water faucet let it run till it stops sputtering and a little extra just to be sure. This is especially important if you use the electric heater. If the heating element is not fully immersed in water it will burn out in very short order.
Another reason to do fill you water heater at home.  If you do this on the road and you are dry camping you may be using up valuable gray water capacity. (IF that is a concern)
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
GLBCamper View Drop Down
Direct Link To This Post Posted: 26 Aug 2015 at 11:06pm
Thanks so much!
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 29 Aug 2015 at 2:27pm
Bumping my question up.
Old: 2014 177 HRE
2016 F150 4x4 Sport
Direct Link To This Post Posted: 29 Aug 2015 at 3:07pm
Just connect it to city water. We then run some water through the lines and go out an hit the switch turning on the hot water heater.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 29 Aug 2015 at 4:18pm
You can fill the HWH with city water or from the potable tank.  Either way, open the hot water valve at the sink a little bit at let the air come out until it stops spitting and there is nothing but water coming out of the tap.  If you're filling from the potable tank you might want to top it off.  Then you're you're set to turn on the gas or electric element.
