  New Posts New Posts RSS Feed: new table in 178
Topic Closednew table in 178 - Event Date: 14 Nov 2015
Direct Link To This Post Calendar Event: new table in 178
    Posted: 17 Nov 2015 at 9:38am
Did you make the hardware (the removable supports)?
Pod People View Drop Down
Direct Link To This Post Posted: 18 Nov 2015 at 9:13am
yes, we made all of the table hardware.  the aluminum braces are 1/4" flat stock with small lag bolts attached to the legs.  I used star knobs and steel tee nuts (1/4x20) from Woodworkers Supply (woodworker.com) for the connectors.  Standard piano hinges were cut to length for the leg to table top hinge connection. Hope this helps you-let me know if you need more details.
I started with a mock-up and the table top was larger.  We keep cutting it down in size until we thought it was as large as possible while still being usable and would fit as we wanted it.  then we made the real unit
Vann
Vann & Laura 2015 RPod 179
Commander203 View Drop Down
Direct Link To This Post Posted: 18 Nov 2015 at 9:22am
Very nice table. I have zero talent when it comes to working with wood. I can't even saw a straight line.lol
Mike & Erin
2013 Tundra 4.6L V8 (Tow PK)
2006 Honda Goldwing GL 1800
2005 Honda VTX 1800N
Direct Link To This Post Posted: 18 Nov 2015 at 6:25pm
Commander, I'm much like you but believe it or not I'm planning on making custom kitchen and bathroom cabinets in the nearer future with my father-in-law.  Not the fronts or drawer boxes (for the nice dovetail look), those I will order custom and unfinished.  All of the enclosed surfaces will be furniture grade plywood and then if we don't paint, solid wood for the exposed ends.  I figure even with buying some tools I need like a decent table saw, I'll still save about $20k over the quotes we received last year.  Plus then I can fit everything perfectly around the appliances.
