Bathroom door issue |
pnwcamper
Newbie Joined: 22 Sep 2015 Location: Oregon Online Status: Offline Posts: 38 |
Topic: Bathroom door issue Posted: 14 Feb 2016 at 9:19am |
The top half of my bathroom door on my 2014 177 is rubbing against the door frame, there is plenty of room from the door nob down to the bottom of the door.
I suppose I could plain down the door but curious if anyone else has an idea? Btw, all the hinge screws are tight. Thanks |
2014 R-Pod 177
2009 Toyota Tacoma Access Cab 4.0 V6 |
Posted: 14 Feb 2016 at 11:11am |
Ours warped slightly, outward like yours but not towards the frame. Probably particle board which may not plane well.
ron_whitt
Senior Member Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
Posted: 14 Feb 2016 at 11:38am |
I used to work at a place where I put together pre-hung interior doors. Try putting a small shim behind the bottom hinge, that will draw the top of the door away from the door frame. Sometimes that will help.
Ron & Shirley
2020 Tacoma 2012 177 rpod |
codycountry
Senior Member Joined: 26 Jan 2014 Location: Wyo Online Status: Offline Posts: 168 |
Posted: 14 Feb 2016 at 11:41am |
Same thing on my 2013 177. It was the plastic molding that needed fixing. All it took to fix it was some good glue behind the plastic trim to suck it over tight against the wall jamb. Glue and shim it tight away from the the door until it's set up and dry, to create a 1/4 or more gap so the door isn't hitting it. That ought to fix the problem.
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1218 |
Posted: 14 Feb 2016 at 2:08pm |
If the above ideas do not help and if you have a bar clamp that you can reverse and use to spread the door opening near the top that may help. When we had our r-pod the back window was difficult to slide open or close I used a bar clamp to expand the opening and it helped. You just need to be careful not to expand it to much but the walls and framing will have a little give without doing any harm.
Podster
Posted: 14 Feb 2016 at 9:34pm |
Yes, same here on the 178. I pulled the door off and trimmed it some and refinished it. No biggie.
Cliff & Raelynn
