  New Posts New Posts RSS Feed: Dried Black Goop
Topic ClosedDried Black Goop
bcpatrick View Drop Down
Direct Link To This Post Topic: Dried Black Goop
    Posted: 08 Mar 2016 at 6:20pm
I decided to go ahead and flush my freshwater system (didn't winterize because it doesn't freeze here), and noticed that the low drain points are covered up with the black coating that Forest River uses to seal everything up. Anyone know how to get this black stuff off? I really don't want to replace the drain ends.
Direct Link To This Post Posted: 08 Mar 2016 at 6:45pm
just peel it back as far as needed.
Direct Link To This Post Posted: 08 Mar 2016 at 7:49pm
Thanks - I finally got it pulled back using brute force. I was surprised that hot water was coming out because the hot water heater isn't turned on, but in any case - the pod is drained...
UPDATE: What a dummy... I left the electric hot water switch on outside. Fortunately I caught it before it sat too long.
Direct Link To This Post Posted: 09 Mar 2016 at 12:34pm
It only takes a second to blow the heating element so hopefully you caught it before the WH was fully drained.
Direct Link To This Post Posted: 09 Mar 2016 at 2:23pm
Yeah - hopefully I didn't just learn an expensive lesson! I'm going to drain again and test in a bit...
Direct Link To This Post Posted: 09 Mar 2016 at 7:43pm
Cheap and not too hard to replace if you did.
