  New Posts New Posts RSS Feed: Chirp sound
Topic ClosedChirp sound
Direct Link To This Post Topic: Chirp sound
    Posted: 25 Mar 2016 at 10:06pm
That is the LP detector.  It uses too much power to run on a small battery.
Direct Link To This Post Posted: 25 Mar 2016 at 10:09pm
The LP detectors can go bad. I had to replace ours one month after we bought our 179. Real easy to replace.
Direct Link To This Post Posted: 26 Mar 2016 at 6:37pm
Note that all 3 detectors have expiration dates, something to keep an eye on.  When I bought my current camper 2 of the 3 detectors were expired.
john in idaho View Drop Down
Direct Link To This Post Posted: 26 Mar 2016 at 8:01pm
3 detectors, huh? Where is the third one?
JohnBG View Drop Down
Direct Link To This Post Posted: 28 Mar 2016 at 8:39am
Depending on what model you have thy might be in slightly different locations.
The smoke detector hangs from the ceiling, ours inconveniently mounted right above the microwave/convection oven.  Runs on a 9V battery and will chirp when the battery is weak.  The cover swings off to one side where you can replace the battery.
The carbon monoxide (CO) sensor is on the wall near the ceiling above the bed.  It also runs on a 9V battery that should chirp if the battery is weak or the sensor is going bad.  They have a date stamp on them and should be replaced every 5 years, mine went bad last year as it's a 2010 model.  The whole sensor twists off from a bracket that secures it to the wall and there is a battery compartment on the back where you can remove and replace the battery.
The third sensor is a propane sensor, which is hardwired and runs off the campers big 12V battery, usually on the dinette seat about 8 inches to a foot off the ground, looks like a gray square box with a green LED on the front of it.  Ours has never chirped but alarms loud and steady.  I've found that sometimes stinky sulfur water fumes from a campsite can trip it.  It's only gone off twice and both times we had the gas tank shut off.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Direct Link To This Post Posted: 28 Mar 2016 at 10:57am
so I changed the battery in the CO detector.  Will check for the smoke detector in the kitchen - probably change it as well.
