  New Posts New Posts RSS Feed: How tight is your cover?
Topic ClosedHow tight is your cover?
jburns View Drop Down
Direct Link To This Post Topic: How tight is your cover?
    Posted: 22 Nov 2015 at 1:31pm
Bought the appropriate size cover for my pod off amazon but man... It's a tight fit.
I tossed the box last recycle day when I cleaned the garage now I'm hoping I'm not screwed and it works.
Any tips? Do others that use the cover find it tight as well?
Thanks all.
J
Q7-retired View Drop Down
Direct Link To This Post Posted: 22 Nov 2015 at 6:14pm
We bought the PolyPro sized for the RP178, model 3 if I recall correctly.  It was tight going on, but fit only snugly when zipped into place.  I managed to get it on by myself with many ladder repositionings (that HAS to be a word!) required.
Best regards, Jim
2015-RP178
TV 2015 Audi Q7 TDI and 2017 Ford F150
At home in "Our Pod"
TigerPawd View Drop Down
Direct Link To This Post Posted: 04 Dec 2015 at 11:25am
I had been thinking the length of a #179 was 20' tip to tip, but when I measured for a cover, I got 21'4", including the spare and going all the way to the end of the tongue, which is what is asked for.  Not too surprising, Camping World was no help.
Have any other #179 owners run up against this?  If so, what size is right, 18-20' or 21-22'?  I would rather not waste $30 on the bigger cover if it's not necessary and fooling with a bigger cover doesn't sound like a lot of fun.  I would appreciate any help on this.
Joan, Jerry and the two Pugs
2015 R-Pod 179
G-Pod View Drop Down
Direct Link To This Post Posted: 04 Apr 2016 at 1:46am
I bought the Classic Accessories Overdrive PolyPro III on Amazon for my 182G and it fits great. Not too tight, not too loose. It hangs over the wheel wells and all other parts of the body. It does not cover the tongue nor anything on it.
Direct Link To This Post Posted: 04 Apr 2016 at 6:26am
I store mine inside to hibernate during the winter (which is still in full force here) but would think you would want a tight fit because a loose fitting cover would "move around" and "slap" back and forth against the finish causing blemishes on wear spots; just my 2 cents worth.
Direct Link To This Post Posted: 04 Apr 2016 at 8:35am
None of the pod covers go over the front accessories. Our cover fits fine.
john in idaho View Drop Down
Direct Link To This Post Posted: 04 Apr 2016 at 10:12am
The important anchors are those pictured in front of, and behind the axle.  If "poofing" in the wind is a problem, one can throw a line over the top fore and aft to cut down or eliminate the billowing.  I use that method - the over the cover tiedown anchors - on my hay stacks, and rarely have to chase down a tarp.
GLBCamper View Drop Down
Direct Link To This Post Posted: 04 Apr 2016 at 5:19pm
I have a 177 and use a #2 size cover (Classic Accessories from Amazon, says it's for up to 18'8"). It is not as tight as furpod's pic, but it's still what I would consider a perfect fit. Personally, I think a really tight cover would stress the seams and material and thus it wouldn't last you as long. But I say, if it goes on and you don't have the box anymore, then use it and don't worry about it!
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
ShadowMac View Drop Down
Direct Link To This Post Posted: 06 Apr 2016 at 11:11pm
I've read conflicting sizing information as I've sought a cover for my 182 G.
Did you go with the 18' 8", or the 20' cover for your 182G?
2017 182-G
Toyota Tacoma TRD Sport
"Try not. Do or do not." - Yoda
fonseca179 View Drop Down
Direct Link To This Post Posted: 07 Apr 2016 at 9:04am
Here is our 179
