  New Posts New Posts RSS Feed: Slide out cover
Topic ClosedSlide out cover
JHoffman View Drop Down
Direct Link To This Post Topic: Slide out cover
    Posted: 11 Apr 2016 at 10:04pm
We have the 176T, I'm also thinking about adding more snaps to the bottom of the tent to snap it to the bottom side of the bed.  There are only two on it now, one at both inside corners.  Our old pop up camper was fastened at several places all the way around the pirimiter.
2016 176t Rpod the "Hoffpod"
2010 Toyota Tundra 5.7L
Direct Link To This Post Posted: 11 Apr 2016 at 11:33pm
Originally posted by JHoffman
I like the simplicity of the cover but I'm not to keen on the bungees. I'm thinking that installing stainless steel snaps every 10-12 inches would look much nicer.  Something similar to the way RV skirting is installed.
The bungees were stopgap on the one I made. Currently, I am using parachute cord on the three middle ones that extend most of the way down and then short bungee cords for the rest. I did not have a chance to take pictures because I was getting ready to leave on a trip.
I also thought of using snaps. The problem was that I could not locate any suitable snaps before I had to leave, so I chose the best available option.
As for leaving it on or removing it, for now, I am removing it for travel. Ultimately, I want to figure out a way to roll and stow it in place. I just did not have time to do so.
As soon as I can, I'll post a couple of updated pictures.
GLBCamper View Drop Down
Direct Link To This Post Posted: 12 Apr 2016 at 5:48pm
I like that idea, but how would you attach snaps to the pod? I would hate to use screw snaps and I doubt "peel and stick" would last long.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 12 Apr 2016 at 7:36pm
I was thinking that stainless steel marine snaps with a dab of sealant under the snap would be ok. If it works on boats it should work on a camper.  The screw will mostly seal itself and the dab of sealant will take care of the rest.  Figured it wouldn't be any different then screwing a light fixture or outdoor speaker to the side.
SandD View Drop Down
Direct Link To This Post Posted: 12 Apr 2016 at 8:40pm
These would work better than snaps for holding power.
http://www.sailrite.com/Common-Sense-Fastener-Cloth-to-Surface-Complete-5-8-Screw
There are two types of people in the world. Those who like RPODs and those who are wrong.
Rpodder
2014 RPOD 178
06 Tacoma Prerunner TRD
Direct Link To This Post Posted: 12 Apr 2016 at 9:42pm
I like that idea. I've seen those before but forgot about them.
Direct Link To This Post Posted: 13 Apr 2016 at 4:22pm
SandD, Those have the same issue as snaps in that it will require drilling holes in the metal or the fiberglass. I would not mind if it were just long enough to go through and be backed up by a locknut or lockwasher and nut, but the screws are much too long. Cutting them off after installing would really be a pain. There would also be the risk of damaging it while doing so.
The cords and short bungees seem to be the better solution for now. I am still looking for a viable alternative.
Edit: I just posted a new picture in my mods which shows the improved attachment method I am using.
Direct Link To This Post Posted: 20 Apr 2016 at 5:45pm
Just an update. It was just 10 days from order placed to delivered for my PaHaQue slide cover! Can't wait to try it out!
Old: 2014 177 HRE
2016 F150 4x4 Sport
