  New Posts New Posts RSS Feed: Removing the A/C
Topic ClosedRemoving the A/C
ToolmanJohn View Drop Down
Direct Link To This Post Topic: Removing the A/C
    Posted: 04 May 2016 at 6:34am
 I would say that even if someone towed unsafely or not, you can be sued regardless. Being faultless in an accident does not mean you can't be successfully sued for having done nothing wrong. Believe it.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 04 May 2016 at 7:11pm
But obviously doing something against the manufacturers recommendations gives those who sue the ammo they need to win.
2011 R-Pod 177
2010 Ford F-150
abejita76 View Drop Down
Direct Link To This Post Posted: 04 May 2016 at 8:28pm
After speaking with multiple dealers & learning that each unit is weighed at the factory and labeled - and there is no way to guarantee the weight, even when special ordering - we've opted not to proceed with an R-Pod at this juncture. I would have been very upset if we ordered one sans A/C, M/W, etc and it still ended up weighing >2400#.
I can't understand how there is such great variability between the same unit floor plan with the same options, or how they get away with advertising some as 2137#... What happened to quality control?
Maybe someday.
Thank you to all who replied.
Direct Link To This Post Posted: 04 May 2016 at 8:37pm
That is probably the best decision for the present. If and when you are able to upgrade to a better tow vehicle, then you will already know about the R-Pod.
Direct Link To This Post Posted: 04 May 2016 at 9:21pm
Just for the liability reasons, you made the right choice.  Once you add your stuff you can add hundreds of pounds more.  My rule of thumb is stuff + full water tank will approach an extra 1000 pounds, so a 171 fully loaded will be pushing the limits of the 3500 pound towing limit that you find on minivans.  Which is why we usually suggest a 5000 pound limit, minimum.
You could look for a 151, which is smaller than the 17x line and came in around 1900 pounds.  Few were made so it would be harder to find one, but they do occasionally pop up here.  If you packed carefully you would be at your limit - but legal.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 06 May 2016 at 5:51am
Thank you for making the right decision.
"Ray & Connie"
- 2017 R-Pod RP-180
dr.becky View Drop Down
Direct Link To This Post Posted: 06 May 2016 at 11:39am
I would like to thank this group for being kind and thoughtful.  I did not get a sense of meanness that can be so pervasive in internet dialogues.  Kudos to all!!
