  New Posts New Posts RSS Feed: E2 WDH model recommendation
Topic ClosedE2 WDH model recommendation
CharlieM View Drop Down
Direct Link To This Post Topic: E2 WDH model recommendation
    Posted: 21 May 2016 at 10:31am
The closer to level the better. Just a few degrees or inches of tilt front to back will affect the settings. Take your wrenches, pad, and tape measure to a schoolyard on a weekend or a churchyard on a week day. Proper setup will take several iterations. A PITA but it's worth it.
Retroactive View Drop Down
Direct Link To This Post Posted: 21 May 2016 at 10:52am
I might have to take it to a local mall etc. Our high school is only 3 miles from my house, but it seems to have a game or practice going nearly 24/7...
GLBCamper View Drop Down
Direct Link To This Post Posted: 21 May 2016 at 4:47pm
What is the best location to check for tow level? I have a bubble T level that I set in the middle of the floor for set-up, but I find that varies from level on the tongue portion of the frame for towing. AND that is also slightly off from checking level on the frame toward the rear of the pod. AND and I find that if I adjust for frame level at the tongue it just "looks" a bit off.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 27 May 2016 at 11:41am
I bumping my last question. I'd really love some input.
Old: 2014 177 HRE
2016 F150 4x4 Sport
Direct Link To This Post Posted: 27 May 2016 at 11:50am
In fact, it makes no difference in the real world. If it's level at any place (floor, counter, tongue) it will be close enough for you and the fridge. The only time you might want to be more selective is if you're running a calibration on tank levels for a SeeLevel gauge system. Even then, replicating that degree of levelness at a campsite is of marginal value. I usually check on the floor or counter top for side to side level, then with a bubble on the tongue for front to back. For towing aspect, anywhere is adequate.
Direct Link To This Post Posted: 27 May 2016 at 1:05pm
I've noticed slight variations from the tongue to the floor.  When leveling for comfort I use the floor as my measuring point.  When setting up the WDH I used the tongue.
Direct Link To This Post Posted: 27 May 2016 at 1:33pm
Yes, there can be slight side-to-side differences between tongue and floor due to frame twist and/or bubble sensitivity. Worse on two axle trailers so I use the floor for initial cross leveling, then use the bubble on the tongue after uncoupling. That said, final leveling should always be done with Fred's frozen peas Tongue .
Direct Link To This Post Posted: 27 May 2016 at 9:58pm
With butter.
Island Rider View Drop Down
Direct Link To This Post Posted: 06 Jun 2016 at 6:33pm
Update - I bought and installed  the E2 600. After I got it set up I went back to the dealer where I bought it to have the shank bolts torqued to 250 ft lbs. No way could I do that with my tools.
Have only tested it out with short runs locally but it seems to working fine. I'll see how it works when we take our next trip.
Dan
Vancouver Island
2016 179, 2016 Tundra
Direct Link To This Post Posted: 07 Jun 2016 at 1:16pm
Should be a nice improvement.
