B&K-Joslin
Calendar Event: Mods to R-Pod 179 Posted: 21 May 2016 at 4:18pm |
1. Change entrance step to 2-steps.
2. Installed a window in the door.
3. Installed a "pull-out" shelf in the coroner cabinet, under the cook top.
4. Installed a T-paper holder up and under the bathroom sink.
5. Moved the 3 pouch holder, in the bathroom, up 6", so it will stay UP, when being used.
6. Removed the hanging rod in the closet and added 6 shelves, to store 6 tubs.
7. Added a shelf over the bedroom bed, to hold "C-Paps"
8. Replaced the couches with a 7" thick futon mattress.
9. Attached Velcro to the shower curtain and to the wall. To help keep curtain closed.
john in idaho
Posted: 21 May 2016 at 6:33pm |
Do you recall where you got the two steps?
B&K-Joslin
Posted: 21 May 2016 at 7:12pm |
I called my dealer, where I purchased the R-Pod. He sold it to me at cost, $86.00
The spets were 1/2 narrower the the original. Nothing a couple washers could not make up for.
P.S. I am in Meadville, PA
Pea Pod
Posted: 22 May 2016 at 12:21pm |
Ha ha......you wrote 'coroner' cabinet. What's in there, skeletons ? LOL
Polly
Posted: 26 May 2016 at 7:06pm |
What size nails or screws did you use and what type of board for the shelves you put in the closet?
GLBCamper
Posted: 26 May 2016 at 7:30pm |
I wondered the same thing! I kept picturing one of those long body drawers at the morgue. I guess the 179 has a LOT more room then the 177!
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Leo B
Posted: 26 May 2016 at 7:40pm |
Ha!! Good one!
GLBCamper
Posted: 26 May 2016 at 8:05pm |
As for steps, I installed these from eTrailer. I just had to enlarge the back screw holes a bit. Otherwise a perfect fit.
https://www.etrailer.com/RV-Stairs-and-Steps/Stromberg-Carlson/SMFP-2100.html
Old: 2014 177 HRE
2016 F150 4x4 Sport
B&K-Joslin
Posted: 26 May 2016 at 8:35pm |
I made 3/4 x 3/4 x 10 square rods to hold up the sides of the metal shelves. The shelf was made, using "Closest Maid" wire shelves. I measured the tubs, that I planed to use for height. Added an extra 1/4" or so, to have 6 tubs. As for the screws I used 1" drywall screw with glue on the wall side.
rmw454
Posted: 02 Jun 2016 at 12:53pm |
I would love to see the pull-out shelf for the cabinet under the stove. I love the 2 steps also, I will have to check into that. We are also looking at putting in the window in the door. Did you install it or have someone install it for you? Great mods.
