Page 12> |
Author | ||
WillThrill ![]() Senior Member ![]() ![]() Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
![]() Posted: 25 May 2016 at 1:31pm |
My wife, our one year old daughter, and me are about to go on a month long trip with our Pod to California and Oregon. We plan to drive about 4,000 miles and will visit Yosemite (we scored a campsite down in the valley!
![]() Here's our problem. Our daughter bathes in a removable baby tub that normally rests inside a full sized tub. It would be a bit bulky to take with us on the trip, but we're thinking that if we could stop up the sink in the bathroom floor of the Pod, that would give her a couple of inches of water to splash around in and for us to bathe her. So has anyone discovered an easy way to stop up the drain? I'm not sure if I should just remove the grate and get a plug that will stick in. My wife has found drain covers that lay flat, but I'm not sure how secure they will be. Any ideas?
2014 Hood River 177 2005 GMC Envoy XL |
Retroactive ![]() Senior Member ![]() ![]() Joined: 15 Mar 2016 Location: Bolton, MA Online Status: Offline Posts: 270 |
I would not attempt to use the 177 Wet Bath as a Bathtub. The seams are "water resistant", not "waterproof".
We only want to put a couple of inches of water in there for no more than a few minutes at a time. Do your really think that will make it leak? It's a shower after all.
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
I would go to Google or Amazon and search for collapseable - folding camping sink. The come round and square
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
You'll have to check to see if it works, but how about just putting a square of Glad Press n Seal over the drain? The stuff works amazingly well with minimal contact area and leaves no residue when you remove it.
By amazingly well, I mean: take a red solo cup, fill it with water to within 3/4" of the brim. Take a square of Press n seal and cover the cup, sealing it only 1 1/2" down/around the neck (and cut off the rest). You can turn the cup upside down, shake it, toss it in the air and catch it and it won't leak a drop. And, yes, the shower pan itself is waterproof. Putting a couple inches of water in it isn't going to cause any trouble.
I took out the original cover and replaced it with a mesh strainer my wife picked up the at Dollar Tree, they came as a set of 2, the other one is in the kitchen sink. The drain is 1 ¾” diameter so you can pick up a rubber sink stopper/plug to seal it
JandL
techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
I agree a few inches won't be a problem. Happens all the time when the gray tank fills up in the middle of a shower. Is the drain on yours not a standard round one that can take a standard rubber stopper?
That's an awesome idea! I had forgot about how useful that stuff can be. We'll definitely do that. Thanks a lot!
It's not sunken in like the kitchen sink drain, so an ordinary rubber stopper won't work. My wife had found a rubber stop that seals on top of the drain, but I think that the Press 'n Seal is an even easier solution, and we can use it for other purposes as well.
All you need is a Charles Viancin lily pad lid in the shower pan. It's what we use for Bob. Bob is our 30 year old turtle and likes to hang out in a few inches of water...with a plastic palm tree. These are great for leftovers in the fridge too!
http://www.amazon.com/Charles-Viancin-Lilypad-Lid-Set/dp/B00PRLC2VM/ fred P.S. Really! This is Bob! We had a portrait done a few years ago. ![]() |
OK, I stand corrected, the turtle knows best!
Page 12> |
