LP gas indicator |
Post Reply | Page <123> |
CharlieM
Topic: LP gas indicator Posted: 10 Jun 2016 at 12:21pm |
We techies do both. Two tanks/autoswitch/ultrasonic. Got to have something to play with!
Guests
Guest Group |
Posted: 10 Jun 2016 at 12:23pm |
Darn it Charlie, I thought I had finally found something that I could disagree with you on! |
CharlieM
Posted: 10 Jun 2016 at 12:35pm |
Keep trying, David. It keeps me on my toes. |
Guests
Guest Group |
Posted: 10 Jun 2016 at 1:12pm |
You don't make it easy! |
ron/roscoe
Groupie Joined: 13 May 2016 Location: Hanahan, SC Online Status: Offline Posts: 84 |
Posted: 10 Jun 2016 at 1:53pm |
Ok, where do I get a steak saver adapter, how much?
Ron Rowland
Posted: 10 Jun 2016 at 4:23pm |
I disagree with you Charlie. The hot water method is very easy and very reliable, provided there is enough of a temperature differential in the hot water and the ambient temperature. IOW, it works quite well in winter. I'm not so sure about the desert southwest in summer though. When we went to visit out daughters in Nevada and Arizona last winter, I used the hot water method. It was obvious where the liquid line was. I could feel it as the tank above the liquid level would be warmer than the tank below the liquid level.
Also, if a lot of propane is being used, simple high humidity can indicate the level. I've seen the condensation at the liquid level and below on my BBQ grill. I didn't even have to pour hot water on the tank. |
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 10 Jun 2016 at 5:28pm |
https://www.amazon.com/Steak-Saver-Adapter-Propane-Connector/dp/B00KYDJ694/ref=sr_1_2?ie=UTF8&qid=1465593809&sr=8-2&keywords=propane+steak+savAlser also available at Camping World, sometimes at Harbor Freight. |
ron/roscoe
Posted: 10 Jun 2016 at 9:08pm |
Question? How the hell did all the good people in this forum get soooo smart?
Ron Rowland
Posted: 10 Jun 2016 at 9:17pm |
WE broke a lot of stuff.
PilotPodder
Posted: 10 Jun 2016 at 9:44pm |
This one has worked well for me...
