  New Posts New Posts RSS Feed: Stabilizer jack question
Topic ClosedStabilizer jack question
Graham&Rory View Drop Down
Direct Link To This Post Topic: Stabilizer jack question
    Posted: 13 Jun 2016 at 1:00pm
Hi there-I have a question regarding the stabilizer jacks on my Pod (2016 182g HRE).  When engaging my stabilizer jacks I simply get them pressed firmly up against the boards I bring for this, being careful not to use them too much so they are not lifting the camper.  My question however is the trailer still has a little bit of sway even with all four down, the wheels chocked and the hitch jack down.  Is this normal?
hogone View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 1:38pm
will be interesting to see what others say, but my answer would be yes; mine does slightly as well. hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
ronahue View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 1:50pm
On pavement or concrete I just snug the stabilizers, on other surfaces I snug plus a half turn then check them the next morning for settling.
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
john in idaho View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 2:02pm
I turn mine down with the battery powered drill, with the torque setting at 10 or 12.  On dirt it does push into the ground a little bit, but I figure that is about the same as standing inside and moving around.
Direct Link To This Post Posted: 13 Jun 2016 at 2:04pm
It is normal, both my pods did that. After a while, you don't even notice it.
TheBum View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 3:54pm
I put a tiny bit of weight on mine to make sure they're snug. The trailer raises between 1/4" and 1/2", but the vast majority of the weight is still on the wheels and tongue jack.
Gregm View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 4:02pm
I always have a little sway More so on dirt but I use boards when not camping on concrete pad we also had this issue with A Viking pop up that we used to own
Gregm
2014 171
2015 Toyota Tacoma Prerunner
sailor323 View Drop Down
Direct Link To This Post Posted: 13 Jun 2016 at 5:51pm
Some sway is normal.  The amount of sway depends on how far the stabilizers are extended.  It is possible to limit the amount of sway by setting the jacks on large blocks.
HongsterRP View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 1:20pm
I always bring with me 3 scissor jacks for extra support.  I like mine firm.
Direct Link To This Post Posted: 14 Jun 2016 at 1:29pm
Where do you place them?
