  New Posts New Posts RSS Feed: Power Jack ?
Topic ClosedPower Jack ?
mjh203 View Drop Down
Direct Link To This Post Topic: Power Jack ?
    Posted: 14 Aug 2016 at 9:50am
I am looking for recommendations for a power jack for my R-Pod 178.  Also, this is probably a question I should know the answer too but I don't so... If I have a power jack and my battery goes dead, will plugging the 7 way into my truck instantly give it enough juice to operate the jack?
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 14 Aug 2016 at 12:50pm
Maybe this isn't the solution for everyone, but I replaced the crank on my stock jack with a hex nut the same size as the shafts on the stabilizer jacks.  I use an 18v cordless drill for both now.  Less work  and a lot less expense than buying a power jack.  The drill has plenty of power for cranking the trailer up or down quite a few times.
Direct Link To This Post Posted: 14 Aug 2016 at 1:06pm
That's a good tip!
Direct Link To This Post Posted: 14 Aug 2016 at 8:17pm
+1.
But if you decide to get a power jack I use a Husky brand jack with my current trailer.  Get one that is rated at least 3000 pounds if you have a WDH since you will be lifting the rear of the TV, too.
Direct Link To This Post Posted: 14 Aug 2016 at 8:37pm
I purchased the Jack Quick model for our R179. The link will take you to pictures of it installed. It has a 3650 lb capacity and costs $111.61 on Amazon. It is a Prime item if you are a member.
Direct Link To This Post Posted: 14 Aug 2016 at 8:52pm
Thanks for the info!
Direct Link To This Post Posted: 18 Aug 2016 at 1:52pm
I followed StephenH's lead  and purchased the  the Jack Quick 3500 JQ-3500B 12v electric tongue jack. It is still on Amazon for the $111.61. We have the Amazon Prime so we got free shipping with 2 day delivery.It has the 3650 pound capacity. It was a very easy install and will make set up quite a bit easier.
Thanks StephenH for the info!
Direct Link To This Post Posted: 19 Aug 2016 at 10:02pm
I am glad you found the information useful.
Bovine0001 View Drop Down
Direct Link To This Post Posted: 27 Aug 2016 at 10:48am
Maybe this isn't the solution for everyone, but I replaced the crank on my stock jack with a hex nut the same size as the shafts on the stabilizer jacks.  I use an 18v cordless drill for both now.  Less work  and a lot less expense than buying a power jack.  The drill has plenty of power for cranking the trailer up or down quite a few times.TT
how did you do that?  My crank does not simply come off.
2014 Rpod 178
Mods in Order:
1: Added USB charging port
2: Added Spigot at Fresh Water to make easy empty
3: Solar Panel
4: Cut dinette bench panel to improve access underneath
JScottHouse View Drop Down
Direct Link To This Post Posted: 27 Aug 2016 at 12:02pm
Yes, plugging in the tow vehicle will provide the power for the jack .... Provided the seven way is wired with a charge wire.
2016 RP-180
2013 Ford Explorer 4WD
