  New Posts New Posts RSS Feed: 179 Door Issue
Topic Closed179 Door Issue
MDPaddlersPod View Drop Down
Direct Link To This Post Topic: 179 Door Issue
    Posted: 24 Aug 2016 at 5:09pm
I have to slam the door to get the catches to engage, does anyone else have this issue?
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
JHoffman View Drop Down
Direct Link To This Post Posted: 24 Aug 2016 at 5:46pm
I had to adjust the latch plates for both my main door and the screen door, it sounds like yours are set a little too tight, loosen the screws and move the latch plates outboard a little bit at a time until the door latches easily but still makes a good seal.
2016 176t Rpod the "Hoffpod"
2010 Toyota Tundra 5.7L
Direct Link To This Post Posted: 24 Aug 2016 at 5:55pm
JHoffman, the latch plates are not adjustable. I already looked at that, like adjusting a strike plate on a home door. The plate is screwed into the door frame without slots to adjust. I may have to make slots in the strike plate with a dremel tool.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
bjk View Drop Down
Direct Link To This Post Posted: 24 Aug 2016 at 10:57pm
You should be able to take it back to the dealer under warranty repair.
When I got my 179, the door latched normally, but it wasn't until my first trip did I discover that the deadbolt wouldn't lock (jamb/lock were misaligned).   I had to lock the door from the outside and then close the door (and make sure I had a spare set of keys in the truck for when I locked myself out). Smile
I was able to take it back and have this corrected by the dealer under warranty.
2016 HRE R-179 "CapPODccino"
2011 F-150 SLX
Direct Link To This Post Posted: 24 Aug 2016 at 11:11pm
Thanks, I will get with the dealer.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
