Mounting sewer hose storage outside frame |
Post Reply | Page <123 |
Retroactive
Senior Member Joined: 15 Mar 2016 Location: Bolton, MA Online Status: Offline Posts: 270 |
Topic: Mounting sewer hose storage outside frame Posted: 09 May 2016 at 8:50am |
We store an extra tank in the pod while towing. We put the tank into a milk crate and then use bungee cords to keep it from sliding around. Once we park we just put the tank out by the tongue. No biggie since it takes me less than 5 minutes to swap the tanks.
Patriot Dave
Senior Member Joined: 06 Feb 2016 Location: LaSalle, Mi. 48 Online Status: Offline Posts: 206 |
Posted: 09 May 2016 at 9:44am |
Thanks for the reply. |
Dave & Joyce
Never Forget, In God We Trust; This Our National Motto. Member; Patriot Guard Riders, Michigan Chapter Retired; So Every Day is Saturday.... Except Sunday |
Retroactive
Posted: 09 May 2016 at 10:03am |
I have decided if I am going to add any extra weight to the tongue, then it will be to mount the spare on it. I am currently searching threads to see if anyone successfully mounted the spare under the tongue.
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 09 May 2016 at 12:22pm |
Getting back to the original topic this is what I did for sewer hose storage ,
Jo and Gary 2010 174 2011 Ford 150 |
Posted: 09 May 2016 at 10:14pm |
I like your hose storage setup, especially the slide-out.
Craneman
Posted: 10 May 2016 at 10:33am |
Bump
NutPod
Newbie Joined: 29 Jul 2016 Location: Canada Online Status: Offline Posts: 25 |
Posted: 04 Sep 2016 at 6:47pm |
I used two L brackets and self tapping screws and mount the honey tube holder to the frame behind the spare tire.
Duer
Newbie Joined: 02 Sep 2016 Location: ON - Ontario Online Status: Offline Posts: 11 |
Posted: 05 Sep 2016 at 7:49am |
Looks like a great idea.
1.) Would you tell us the clearance from the tube to the ground please? 2.) Do you travel on gravel roads or do any boon docking with this set up? Cheers, Duer |
Duer
NutPod
Posted: 05 Sep 2016 at 12:03pm |
Clearance is great, it sits right on top of the spare tire hitch and I used the "L" brackets to bolt onto the tube and then it lines up with the end of the trailer frame to secure it with self tapping screws. Not sure of the distance to the ground at the moment but if you bottom out you will damage the spare tire first if that helps.
