Home Thermostat |
Grandpa Hiker
Senior Member Joined: 04 Jan 2015 Location: Martinsville, V Online Status: Offline Posts: 143 |
Topic: Home Thermostat Posted: 08 Oct 2016 at 8:39am |
I would like to turn up the temp in my home while we are gone camping for several days & then turn it back down before we get home. Does anyone have a recommendations on a home thermostat that would allow me to adjust the temp in my home using my cell phone?
Rob & Becky
2014 Ford Explorer 3.5 SOHC V6 2015 R-179 Pod aka Piddle Pod "Life is not about waiting for the storms to pass, it is about learning to dance in the rain!!" |
Posted: 08 Oct 2016 at 9:04am |
I have seen a system at Lowes.. don't know anything about it..
CharlieM
Posted: 08 Oct 2016 at 9:40am |
Such a system usually involves a WiFi enabled programmable thermostat ($$$), a full time internet connection ($$$), a home WiFi system including router ($$$), and a smartphone contract with a data plan ($$$). Seems like a lot of complexity and expense just to avoid setting the stat before you leave. Even if you already have the internet connection, WiFi network, and smartphone you still need the thermostat. We set the house thermostats as we leave and reset them when we return, same as turning the water off/on, the water heater off/on, etc.
Grandpa Hiker
Posted: 08 Oct 2016 at 9:56am |
I have everything except the thermostat. I just think it would be nice to not come back to a hot house.
Rob & Becky
CharlieM
Posted: 08 Oct 2016 at 10:23am |
In that case Lowes offers models from $99 to $249, but I have no knowledge of any. That said, and living in hurricane country, I have remotely operated cameras I check on the road . I also use them to monitor house temperature and power outages. Go figure.
Posted: 08 Oct 2016 at 3:47pm |
I have the Iris by Lowe's system. It is both for security and for home control. I have the Radio Thermostat. I can control it with my phone through the Iris app. I also have two outlets that I can control. I have a light plugged into each of them. We originally got it after we had a break-in while we were gone.
The Iris system went through an "upgrade" which was not as smooth as it could have been. Tech support finally got the remaining issues solved, and my system is working great. Recently, Lowe's released the 4G cellular modem for backup. I had the older 3G system on version 1. It is good to get the cellular backup again as we have had a few outages of Time Warner's Internet service. There are several systems out there that will do what you want. I only have experience with the Iris system. |
ronahue
Senior Member Joined: 02 Jun 2015 Location: Massachusetts Online Status: Offline Posts: 316 |
Posted: 08 Oct 2016 at 7:34pm |
We have 2 Honeywell TH8320WF thermostats that control both zones in our home both the AC and heat and we are very happy with them. We have had them for about 3 years so they probably have an updated model by now. They will also notify you if the heat or AC goes out and if the temperature drops below a pre-set level.
Ron & Sharon
2015 R-Pod 179 2022 Nissan Frontier No trees were harmed in the sending of this message but a billion electrons were really agitated |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3252 |
Posted: 08 Oct 2016 at 8:18pm |
For the past 2 years (in January 2017) I have used the NEST thermostat. It works fantastic and allows you to program, heat or cool your home from your smart phone. Cost was $ 250 but well worth it to us as we can let the house set using minimal electricity while we are away. We have excellent internet service so that isn't an issue. If you lose power and don't have a backup, then the NEST programmable thermostat will obviously not work either. You can program this from your smart phone 24/7 for an entire week, it will then roll over and begin the process over on its own unless you wish to change temp ranges. Check out its features at nest.com
TheBum
Posted: 10 Oct 2016 at 3:04pm |
Make sure that the thermostat is compatible with your AC/heating system. We have a Carrier Infinity system in our house and none of the aftermarket smart thermostats are compatible. There is only one smart thermostat that will work, but it's rather expensive.
