List Your Mods: |
Post Reply | Page <1 5758596061 77> |
Grandpa Hiker
Senior Member Joined: 04 Jan 2015 Location: Martinsville, V Online Status: Offline Posts: 143 |
Topic: List Your Mods: Posted: 03 Nov 2016 at 3:44am |
Installed 6 ft. tool box from Northern Tools. Had to move propane tank 3 1/2" forward. |
Rob & Becky
2014 Ford Explorer 3.5 SOHC V6 2015 R-179 Pod aka Piddle Pod "Life is not about waiting for the storms to pass, it is about learning to dance in the rain!!" |
Alaskaflyer
Newbie Joined: 30 Aug 2016 Location: YNP, WY Online Status: Offline Posts: 18 |
Post Options Quote Reply Posted: 03 Nov 2016 at 11:16am |
Very nice. |
2016 RP-176
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Post Options Quote Reply Posted: 03 Nov 2016 at 1:22pm |
The front led lights must pass by the slide motor under the slide out and they used it to power the slide motor.if you take the cover off your elec panel and just remove fuses you can find which wire and fuse does which lights and which one does the slide. You can also unscrew the main panel and slide it out and see the rats nest they call wiring and tap into any wire you want to switch
rGod2013
Newbie Joined: 06 Sep 2016 Location: Chico, CA Online Status: Offline Posts: 19 |
Post Options Quote Reply Posted: 10 Nov 2016 at 11:41pm |
I give up. Can't figure how to use this site right. I'm sorry but this site is not user friendly, at least not for me. Too much back and forth. Can't figure out how to post things right, even with site help. Things disappear. I started using cut and paste cause I cannot figure out how to pick up my file and place it, (or is it post it?) in a topic? OR am I always making a new topic, or is it a post? I do a search and using the simplest words cannot find a topic I know I've read before. Lots of good info here. I am just having a hard time learning the ropes. thanks for the help |
Post Options Quote Reply Posted: 15 Nov 2016 at 9:46pm |
Post what you are having a problem with so we can help.
CLT-NC R-Podder
Newbie Joined: 18 Mar 2016 Online Status: Offline Posts: 8 |
Post Options Quote Reply Posted: 16 Nov 2016 at 9:31am |
If you're on Facebook check out the R-pod Owners page!! Lots of fun seeing pictures and people helping others with any questions or problems!!
Joe & Erin
2016 178 towed by 2016 Toyota Tacoma double cab 4x4 |
djlmll06
Newbie Joined: 13 Nov 2016 Location: St. Louis, MO Online Status: Offline Posts: 6 |
Post Options Quote Reply Posted: 20 Nov 2016 at 10:53am |
New owners of a 2017 r-179 and made the following easy mods but it makes a big difference. 1. Corner tension bathroom caddy. Make sure you buy one that is not a one piece pole but has 3-4 pieces as to adjust the height correctly we didn't use 2 of the poles. We were on 30 miles of bumpy rock road and it stayed put. 2. Paper Towel Holder - used a small (6-11 inch) adjustable tension curtain rod. Found at Lowes and it comes in a two pack. Used for side lights of doors. I do have to remove it when the slide is in. 3. Toilet Paper Holder - The wet bath can be trying to find a good place for the toilet paper. I used the other tension rod in #2 and put it under the sink. Roll it up while taking a shower and it didn't get wet. |
Dave & Maria
2017 rPod 179 |
djlmll06
Post Options Quote Reply Posted: 20 Nov 2016 at 10:54am |
New to site, not sure why my pictures aren't showing. Help?
Dave & Maria
2017 rPod 179 |
djlmll06
Post Options Quote Reply Posted: 20 Nov 2016 at 11:22am |
How do you post pictures? I browsed found the pictures, uploaded but can't figure out how to get them in my post.
Dave & Maria
2017 rPod 179 |
Cap-n-Cray
Senior Member Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
Post Options Quote Reply Posted: 20 Nov 2016 at 1:03pm |
Dave, Use the Full Reply Editor (arrow in the boxes) and a photo hosting service like Photobucket (free) and post a direct link in the Insert Image icon...
Cary
2014 RP-177 |
