  New Posts New Posts RSS Feed: How much stuff weighs
Topic ClosedHow much stuff weighs
rpodcamper.com View Drop Down
Direct Link To This Post Topic: How much stuff weighs
    Posted: 15 Dec 2009 at 9:11pm
I was doing some playing around looking to see what I could fasten to the front or rear of the R-pod and asked my how much will that weigh.  So here is a quick chart:
Propane weighs 4.25 pounds per gallon
Water weighs 8.3 pounds per gallon
Gasoline weighs 6.3 pounds per gallon
Diesel fuel weighs 6.6 pounds per gallon
Direct Link To This Post Posted: 18 Dec 2009 at 12:31am
    How much extra weight can one place on the front of the RPod outside.    David
2014 Ram 1500 Quad cab
TerryM View Drop Down
Direct Link To This Post Posted: 18 Dec 2009 at 9:05am
I think what might limit that is the tongue weight limit of the tow vehicle.
Terry
Direct Link To This Post Posted: 18 Dec 2009 at 9:31am
     Thankyou for the information. We have a class 2 hitch that has a 300 Lb limit, that doesn"t give us very much extra weight for the tongue. I need to think of a way to get the actual tongue weight. Once I did it with a bathroom scale, but it was very difficult.    David
GATOR View Drop Down
Direct Link To This Post Posted: 18 Dec 2009 at 9:49am
  I used my bathroom scale to weight my 177 Also, It was very simple
with the Pod in the driveway (concreat), put scale directly under toung
of the trailer then put a short 2x6 or 2x4 flat on the middle of the scale then another
short piece of 2x4 standing up directly under the toung. Note the weight of the
pieces of wood ( should be 4 to 5 lbs ) and with the trailer jack, lower slowly until
the wheel of jack comes off the ground. Subtract the weight of pieces of wood.
Quite easy! Mine is right at 200 lbs.
Gator & Tammy
2010 RPod 177
2006 Toyota Tacoma 4x4
Direct Link To This Post Posted: 18 Dec 2009 at 12:39pm
Terry
+1
Structurally the front of the 'pod can handle whatever you throw at it, its the class of hitch you have, in addition to the actual limit of the TV.
Direct Link To This Post Posted: 18 Dec 2009 at 4:15pm
Terry
+1
My TELEVISION doesn't weigh very much!LOLLOLLOLLOL
Terry
Direct Link To This Post Posted: 18 Dec 2009 at 7:40pm
Tow vehicle!  Wink
Direct Link To This Post Posted: 18 Dec 2009 at 10:55pm
I can tell you this about how much can be on the front.  Last weekend had 2 20 Lb Tanks Filled, 2 12 volt batteries, and 2 -  6 Gallon Water Containers.  I need to rethink the water Containers as when I got to the camp site the water was frozen....
I have a Class 3 Hitch on the TrailBlazer
yizit View Drop Down
Direct Link To This Post Posted: 18 Dec 2009 at 11:51pm
Former owner of 2009 172
Darlene & Jim, Ewok our Lhasa
Roada our 2004 Roadtrek C190Popular
