  New Posts New Posts RSS Feed: Mounting to the walls. Inside & Out.
Topic ClosedMounting to the walls. Inside & Out. - Event Date: 01 Apr 2017
Direct Link To This Post Calendar Event: Mounting to the walls. Inside & Out.
    Posted: 30 Mar 2017 at 8:45pm
If you wipe down the wall with 92% rubbing alcohol or with an alcohol prep pad (my wife uses them to do her diabetes blood sugar tests), then the command strips will stick much better. I have not had one fall off when I cleaned the wall first this way.
