PhysicHill
Topic: slideout power requirements Posted: 02 May 2017 at 2:45pm |
Hi, we are newbies and just purchased an 183g--so excited! Is it true that the slideout won't work unless you're connected to AC power? Or would having a second battery solve the power problem? Many thanks for any advice!
Gary and Laura Dooley Chesterfield VA
Gary and Laura
2016 183g
TheBum
Posted: 02 May 2017 at 3:34pm |
It works fine on 12V. If we're boondocking, we typically leave the Pod plugged into our TV until after we've extended the slide.
PhysicHill
Posted: 02 May 2017 at 3:42pm |
Thanks! We have a fully charged Interstate HD-24 marine/RV battery, and the slide out will not operate. SO I guess we have a problem?
Gary and Laura
2016 183g
Posted: 02 May 2017 at 4:09pm |
check that the battery connections are tight, make sure the fuse isn't blown. read up on the scwintek system. it will give you trouble shooting codes on the controller.
1 question , and the answer matters and I am not trying to be rude.. How do you know your battery is fully charged and healthy?
PhysicHill
Posted: 02 May 2017 at 4:53pm |
Thanks, we will get the battery checked--it is showing a full charge but may not be healthy. Thanks for all the great advice.
Gary and Laura
2016 183g
ToolmanJohn
Posted: 02 May 2017 at 4:59pm |
The slide motor will be 12 volt. So if it works plugged into shore power 120VAC, then the converter is providing the 12 volts needed. If It does NOT work when unplugged, then you have a battery/supply connection problem. The battery is not connected? A fuse blew or breaker tripped? Battery is in very poor state? Need to do a load test after 100% charging.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Leo B
Posted: 02 May 2017 at 5:25pm |
Ditto! Depending, the batteries can go flat pretty quick.
TheBum
Posted: 02 May 2017 at 5:58pm |
+1 on the load test. If the battery has developed a high internal resistance, it won't be apparent until the battery starts pumping out amps.
Don&Amy
Posted: 02 May 2017 at 7:07pm |
Gary and Laura Dooley Chesterfield VA [/QUOTE]
Right down the road from us! We are in Powhatan. We will be taking delivery of our 178 in two weeks.
PhysicHill
Posted: 03 May 2017 at 10:42am |
Don&Amy, Great to meet you!!
Everyone else, Thanks for all the great advice. We purchased another battery yesterday and the slideout is working beautifully on 12V. Because the R-Pod is new and the dealer supplied us with a "new, fully charged" marine battery when we picked it up 2 weeks ago, we were second-guessing everything. Turns out that they gave us a dud--we'll get them to replace it!
Gary and Laura
2016 183g
