  New Posts New Posts RSS Feed: Hammock
Topic ClosedHammock
Podwan View Drop Down
Direct Link To This Post Topic: Hammock
    Posted: 23 May 2017 at 11:04am
Is it possible to add a hammock to the inside of an rpod or a t@b trailer without damaging the side walls?
Capt Kidd View Drop Down
Direct Link To This Post Posted: 23 May 2017 at 11:06am
I would think so as long as you attach it to the stud.
The Pirate's Pod
Direct Link To This Post Posted: 23 May 2017 at 11:09am
I would not do so. The wall certainly is not strong enough. The hollow, aluminum stud is also not strong enough to take the stress of mounting a hammock. You would, ideally, need a large backing plate to spread the stress and a bolt through. Since that would look rather ugly on the outside of your 'Pod and since it would make a point of potential leakage, I would not risk it.
Direct Link To This Post Posted: 23 May 2017 at 12:21pm
Thank you!!
Danielw1 View Drop Down
Direct Link To This Post Posted: 23 May 2017 at 11:36pm
Hammocks are for outside around trees! Not only that but how in the world could you fit a hammock inside a rpod?!
