  New Posts New Posts RSS Feed: Solar Questions
Topic ClosedSolar Questions
 Post Reply Post Reply Page  <1 234
djensen View Drop Down
Direct Link To This Post Topic: Solar Questions
    Posted: 08 Jun 2017 at 10:39am
If I were to install and use a solar system, will my electrical outlets be available for use?
Direct Link To This Post Posted: 08 Jun 2017 at 11:28am
Depends on the install and how much money you care to spend. Anything is possible with enough $$$$. But in general, no.
A "solar system" in the way we are talking about them here, is for charging the batteries. Them only thing you give up going off grid is the a/c and microwave. Every other system in the pod can, or does, run on 12v or propane.
Direct Link To This Post Posted: 08 Jun 2017 at 12:00pm
+1. Remember most solar systems you might use for an R-pod are going to be in the 100-200 watt category. That is pretty much what it takes to charge your batteries over a few hours. If your batteries are full, then all of that power is available for other uses. However it's still only 100-200 watts. Not enough to run the microwave. Not enough to run the AC. Probably enough to run the furnace.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 08 Jun 2017 at 6:44pm
The furnace fan and electronics run on 12v, so if you mean solar will maintain the battery well enough to use the furnace, that's probably correct.  A lot would depend on sunlight, outside temps, and how warm you want to keep it inside.
Rustler View Drop Down
Direct Link To This Post Posted: 09 Jun 2017 at 2:17am
Originally posted by GlueGuy
Originally posted by geewizard
My opinion is that a MPPT solar controller wrings out every bit of solar panel output far more efficiently than a PWM solar controller.  And so, it's even more critical to use one with smaller solar panels.  As is using the largest gauge wire between the solar panel and battery.  Every little bit helps when you're beginning with little bits anyway.
The other advantage to an MPPT controller is that you can run the "solar part" of the system at a much higher voltage. This means that in low sun conditions, the panels can actually provide juice to the batteries when a pure PWM system might be able to actually charge.
For example, our 150W panel is designed to be used with a 24V system, so it's output is in the 30-37 volt range. You could not use it with a PWM controller for a 12V battery system. However, the MPPT controller is quite happy with 37 volts input (and even higher), and putting out charging voltages for a 12V battery. In low light conditions, it could actually charge a 12V battery where a PWM system would still be waiting for some more sun.
I completely agree with your thoughts. I didn't realize the added benefit of useable solar output in low or weak Sun conditions. Seems like most people are scared off from using the higher voltage panels, not knowing the MPPT controller does the voltage conversion to charge a 12-volt battery. The higher voltage means much less power loss in lengthy wiring. As was mentioned, using the largest gauge and shortest wire is of great benefit.
My implementation of using a couple of 36-volt panels to power my RPod 171 is described in this post:
While the MPPT controllers are more expensive than PWM controllers, the extra cost more than pays for itself over the years. It's like getting a more powerful solar panel for the size and cost of a smaller one.
Russ
2009 Toyota RAV4
V6 w/ tow package
2016 Rpod 171 HRE
Cfesko View Drop Down
Direct Link To This Post Posted: 13 Jun 2017 at 1:18pm
but did you use the MC4 connector next to the door or straight line it to the battery with clips??
Direct Link To This Post Posted: 13 Jun 2017 at 1:42pm
Most panels these days use MC4 connectors. However, you need the controller in between the panels and the batteries.
What I would be inclined to do is use MC4 to get to the R-pod. What you use on the side of the R-pod would be optional, but if there is such a thing as a panel-mount for MC4, that would be a nice option.
I would then place the MPPT controller as close to the batteries/converter as possible. I'm guessing there is enough space behind the converter to make that a logical place, but that is a SWAG.
Some of our remote solar sites use as many as 5 37-volt panels. We run them in series, which produces ~~ 185 volts. Even in really crappy solar conditions (like heavy overcast), we can get > 60 volts out of this setup. Our solar sites are mostly 48 volt battery systems, and the MPPT controller converts from whatever voltage is coming out of the panels into what the batteries need.
I love MPPT controllers.
