Page <1234> |
![]() Posted: 15 Jun 2017 at 11:20am |
BTW.. if I had to face this, a kids swimming pool of the cheapest variety might be handy..
+1 to furpod. Also I didn't see any mention of using the backflush or one of the wands that goes down toilet. I've had luck with that.
Thou must have offended the camping gods mightily for them to smite you with black tanks woes of this magnitude! ![]() If I had to deal with it, I would approach it as jimandclare suggest. A small 15' (I think) drain snake can be purchased at Walmart for about $15. (I bought a new one a while back to clean my clothes dryer vent.) Drain Auger If the "insertion cut/hole", made in the drain hose is done close to the fitting, it may be able to be repaired, when done, by cutting off a few inches and clamping the slightly shorter hose back on the fitting. I suspect that when things start happening, they will happen fast. Be ready. |
Quoted for truth. and laughs. |
osbornpodppl ![]() Newbie ![]() ![]() Joined: 10 Sep 2016 Location: North Dakota Online Status: Offline Posts: 15 |
I think we're at the point that one starts to build an altar to said camping gods in appeasement. Might even throw in a dance or two around it...If the North Dakota Wind doesn't blow us away first...
(I just got a nasty bump on my head curtesy of the truck door and a particularly strong gust of wind)
We have purchased and used a 15 ft hose, a drain snake for the toilet from the top, a really long thing for the dryer vent that bent backwards and wouldn't go forwards. Now trying a new thing called an RV Flexible Swivel Stick. Will report back soon... |
R-pod 2011 181-g
2010 Toyota Tacoma 4WD Nick and Christina |
Try running the snake from the drain outlet end. It is understandable that it would have little effect when going down the toilet. The blockage is most likely at the low point - from the valve back towards the toilet. Going down from the toilet, the snake is just going to want to "wander around" in the tank. |
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4512 |
Dynamite🤔
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Perhaps you could get a gallon of that colonoscopy prep stuff!! I know for a fact it works for my holding tank (personal, not rv).
As said above...when things start happening, they will happen fast! |
Page <1234> |
