  New Posts New Posts RSS Feed: Tire and Axle Maintenance
Topic ClosedTire and Axle Maintenance
2P$InAPod View Drop Down
Direct Link To This Post Topic: Tire and Axle Maintenance
    Posted: 26 Jun 2017 at 12:35pm
Hi,
We have a 2015 Rpod, which we got new back in April 2015. We have been towing it to campgrounds 1 to 2 hours away from home every other weekend during the last 2 summers. This week for the July 4th long weekend we will be towing the RPod to Acadia Nation Park with our 2017 Traverse. It will be a 5.5 hours drive from home to the campground. Before we head out for our first long drive camping trip, is there any maintenance on the tires or axle we should do?
The only thing I have done so far on the Rpod tires is inflate them when needed. I have not done anything with the axle.
David and Kris
2015 RPod 179
2002 Honda Odyssey LX
Happy Tripping View Drop Down
Direct Link To This Post Posted: 26 Jun 2017 at 1:36pm
There are more expert people to comment on this but the 4th is coming fast.
Have you had the wheel bearings greased??
That I believe should be done annually if the trailer is used much, and you need an infrared thermometer to monitor the bearings' temperature, especially if you can't get the bearings greased before leaving.
I hope you have a small compressor to inflate your tires to proper pressure.
Direct Link To This Post Posted: 26 Jun 2017 at 4:44pm
At a minimum, you should remove tires and grease axle bearings thru zerk in the axle center. Jack up on the riser not the axle.
ArenaBlanca View Drop Down
Direct Link To This Post Posted: 26 Jun 2017 at 6:13pm
The 2017 manual for the Lippert axles recommends every 12,000 miles or every 12 months whichever comes first. Also check tire pressures and lug nuts every week. The most important thing to ensure tire life and safety is proper tire pressures.
Harbor Freight is your friend!!
Enjoy Life!!
GLBCamper View Drop Down
Direct Link To This Post Posted: 26 Jun 2017 at 11:52pm
What Temp should the bearing run? Where is the best place to point the gun?
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 27 Jun 2017 at 7:44am
  A lot depends on ambient temps.  100 to 120 or so for me usually,  Fool around with the gun and find the hottest point near the center.  What you really want to look out for is one hub that's a lot hotter than the other.  50 degrees hotter.  They will vary a little normally depending on which side the sun is on.
  You don't need a temp gun.  You can just feel the hubs.  If they feel a little warm that's good.  If they're hot, not.
Direct Link To This Post Posted: 27 Jun 2017 at 7:52am
+1 - last trip to ERU, mine ran from 103-112, temps were in mid 80s, speed 63 mph. Infared sensor with red dot on the hub. I also check tire heat - to ensure they are similar on both sides, a low pressure tire runs hotter.
Direct Link To This Post Posted: 27 Jun 2017 at 8:52am
I've not had the wheel bearings greased...will have to do that before the trip.
Also, any recommendation on a infrared thermometer.
David and Kris
2015 RPod 179
Direct Link To This Post Posted: 27 Jun 2017 at 10:11am
I have a FLUKE 59, around 40 bucks, I like FLUKE>
E&JOlson View Drop Down
Direct Link To This Post Posted: 27 Jun 2017 at 3:53pm
