  New Posts New Posts RSS Feed: Door hard to open
Topic ClosedDoor hard to open
YODT View Drop Down
Direct Link To This Post Topic: Door hard to open
    Posted: 18 Jul 2017 at 2:44pm
First trip in our new 179 last weekend.  The door was incredibly hard to open - sometimes I had to get both thumbs under the latch and pull super hard.  My wife couldn't get it open at all a few times.  And of course sometimes it opened as easy as can be.  It wasn't locked either, though I'm often known for dumb things like that!
PilotPodder View Drop Down
Direct Link To This Post Posted: 18 Jul 2017 at 2:52pm
I am having the exact same issue with my new 179. I think it must have been fitted in Winter and now with the heat the door has expanded and is sticking. All I can think of is to spray some silicon lube at various points. Let me know if you come up with something better.
Bugout View Drop Down
Direct Link To This Post Posted: 18 Jul 2017 at 3:23pm
The locks stricker plates are adjust sound like you to let them out a little
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
M&M View Drop Down
Direct Link To This Post Posted: 18 Jul 2017 at 3:40pm
We had the same issue with our 179. Finally loosened up after a month or so...
2017 179 "Big Sexy"
2012 Honda Pilot
Direct Link To This Post Posted: 18 Jul 2017 at 7:30pm
We had it happen when we were in Maine, a couple of blasts of WD-40 did the trick
dr2428 View Drop Down
Direct Link To This Post Posted: 18 Jul 2017 at 7:43pm
I have had that issue twice on my new(last August) 179, the door opened and closed smoothly at the dealer. In my case I was too aggressive dropping the stabilizers and it tweaked the frame just enough to cause the door to stick. It just happened again this past weekend but I remembered, raised the stabilizers back up, then back down appropriately and problem solved. Give it a try, may work.
2017 RPod 179
2018 Chevy Colorado Z71 4x4
voisj View Drop Down
Direct Link To This Post Posted: 18 Jul 2017 at 10:06pm
+1
SLOPODMODS
John&Sue,SLO,CA
rawest50 View Drop Down
Direct Link To This Post Posted: 19 Jul 2017 at 8:23am
It happened to me once. What I found my rear stabilizer was barely touching the ground. I guess it allowed the Pod to sad ever so slightly at that corner. Run the stabilizer down and all problems fixed. I make it a point to go around and check all 4 stabilizers a second time.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
TheBum View Drop Down
Direct Link To This Post Posted: 19 Jul 2017 at 2:19pm
Also check to make sure the screen door hinge screws are all the way in. Our 179 was almost impossible to latch from the inside before I ran those screw in the rest of the way.
