  New Posts New Posts RSS Feed: Running the AC with Cover on
Topic ClosedRunning the AC with Cover on
clickscrazy View Drop Down
Direct Link To This Post Topic: Running the AC with Cover on
    Posted: 24 Aug 2017 at 5:02pm
I have a poly pro cover (cheapo one).
It is breathable and has venting at the top.
What are you thoughts on running the AC with the cover on?
2018 R-Pod 171
2014 VW Touareg TDI
Direct Link To This Post Posted: 24 Aug 2017 at 6:43pm
Interesting. I think a RV AC does not use outside air, it recycles inside air. It condensates and expels moisture on the roof, which means you would have a moisture issue under the cover, you may have to deal with that. Personally I would not cover and then run AC, but that's me.
Direct Link To This Post Posted: 24 Aug 2017 at 6:48pm
+1
john in idaho View Drop Down
Direct Link To This Post Posted: 24 Aug 2017 at 9:26pm
I guess my question is ...WHY
spydie View Drop Down
Direct Link To This Post Posted: 24 Aug 2017 at 11:08pm
I question if the AC DOES indeed just recycle the inside air (like when you turn your car AC on maximum, or "recycle" setting) or does it cool the outside air?  (we don't have a setting for recycle like home window air conditioners do).  Either way, there is a lot of air movement from a fan pulling air over the condenser on the outside.  I would question if your breathable cover will restrict any of the air flow.  You would not want to put any burden on a fan/motor as it would shorten its life.
2018 R-pod 176
2017 RAM 1500 5.7L Hemi
Direct Link To This Post Posted: 25 Aug 2017 at 7:56am
If you pull the cover and look at the rooftop unit, you will see there is no provision for outside air to get into the unit. Outside air is used to cool the rooftop unit. There is no filters that would ensure outside particles would not enter the inside unit and stick to moist components. The issue I think is the outside air around the running AC could be 10-15 degrees above the ambient temp. So adding an additional cover could cause the outside to run hotter.
Direct Link To This Post Posted: 25 Aug 2017 at 8:01am
it is closed system.. that's why you have filters inside the pod, but not outside.
Direct Link To This Post Posted: 25 Aug 2017 at 10:59am
The cover is pretty loose. Especially if I open the door flap or pull up the back just a bit. The moisture should not be a problem, it can easily run down the back.
If anyone has one of the poly pro covers, you can literally see through it.
2018 R-Pod 171
2014 VW Touareg TDI
eye95 View Drop Down
Direct Link To This Post Posted: 25 Aug 2017 at 11:06am
Condensed moisture will run off. Uncondensed moisture (humidity) will build under the cover.
Moisture is the #1 enemy of TTs.
<0>
2017 178 The "eye-Pod"
2011 Nissan Titan
Direct Link To This Post Posted: 25 Aug 2017 at 11:50am
Does anyone have this cover? The poly Pro?
2018 R-Pod 171
2014 VW Touareg TDI
