ArenaBlanca ![]() Senior Member ![]() ![]() Joined: 07 Sep 2016 Location: Alamogordo, NM Online Status: Offline Posts: 158 |
![]() Posted: 01 May 2020 at 9:35am |
We are fortunate enough to have two campers -- a big LaCrosse that is our summer home (usually in the cool of Northern NM) and TEN, our R-195 that we travel in. I try to do all the maintenance of the Pod so I drain the water heater, use compressed air to blow out the water lines and drain the tanks, etc.
The LaCrosse is a different story. We had a local service person winterize it and he has used the pink anti-freeze for the last couple of years. Those of us who have experience with this stuff know that it is effective but it leaves a definite after-taste in the plumbing. ![]() ![]() Is there a way to neutralize or remove this after-taste other than running a lot of water through the system??
Enjoy Life!!
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6322 |
After sanitizing, I have found that draining the chlorinated water and refilling it with water and a cup of baking soda goes a long way toward removing the bad taste. Treat it like you do the sanitizing. Run it through, let it sit for a while, then drain and fill with fresh water.
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1214 |
Personally, I never drink the FWT water. I buy drinking water hoses, I use a filter, but I just feel better using bottled.
2017.5 Rp-172
We have not had any health issues from using the FWT as intended. I think of it as a very large size refillable bottle.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3252 |
Curious as to why you don't used compressed air for the LaCrosse as well. Should be a similar project in scope as the Pod. The first year we owned our 177, back in 2011 we also used the pink antifreeze and had the same problem with the "taste" of the water. Ended up using a couple different concoctions to rid the nasty after taste. First was by using a quart of lemon juice and adding 10 gallons to the FWT and let sit for 24 hours and run through the cold water lines. Secondly we used 2 quarts of white vinegar in 10 gallons in FWT, let sit overnight and then ran it through the cold water outlets. Problem solved, at least it worked for us. Since then, from 2012 till now, we only use compressed air, takes about 2 minutes to go through all lines 2x. After that I use a total of 16 oz. rv antifreeze to pour in the traps and a little above the lid in the toilet to keep the seal moist through our long northern Michigan winters - no problems ever using this method. Yes, we use our FWT for drinking water, only use well water. Interesting as I have observed a lot of posts on the FB site showing the anode toasted after only a year of use. We are going on year 10 and our anode still looks almost brand new. Even though our water is hard it must be due to the fact that there aren't any nasty chemicals added which municipal and city waters must have added to make it legal to drink.
It might not be the chemicals the cities add. Everything else being equal, the anode should be consumed faster when the electrolyte (the water) is more conductive. High calcium carbonate concentrations in water is what is usually thought of as hardness but that isn't the only chemical that can make water more conductive. In the dry southwest the water is generally saltier than in the east, northwest, and midwest, that also increases conductivity. It would take a more detailed look at the chemistry of your well water vs the water in the cases where the sacrificial anode has been more rapldly consumed.
Then you have the duration the anode is immersed and the temperature of the water in the tank, both of which will result in higher annual anode use. Where you live probably you have cooler water in the tank for a shorter period than in some other places. Here is a link to an interesting chart from the USGS on calcium carbonate water hardness. Most of Michigan is kinda medium hard. |
What I don't get is the "wear pattern" on the annode rods. The one we have right now is down to the internal rod where it attaches to the fitting, but the rest of it is only slightly pitted. It's as though all those stray charged particles are having a party in one spot.
I've seen that wear edit:
That is the pattern I see on my anode rod also. The rod next to the threads is gone but there is a lot left on the rest. This anode rod should be good for another year or two. I do carry a spare though.
