GodsPod
Calendar Event: Need help - Leaking roof Posted: 28 Oct 2020 at 6:39pm |
I have a 2016 R Pod 179 that we bought used last February and I have noticed during the last few rainstorms that there is standing water on my kitchen counter(slide side). I tried my hand at caulking what I thought were some cracks along the roof seam to no avail. There seems to be no leakage into the lower cabinet but am plenty concerned. This is my very first post and I don't even know if I am doing this correctly.
Help
Posted: 28 Oct 2020 at 6:44pm |
Is your roof spoiler directly above the leak? The spoiler with lights at rear of RV.
GodsPod
Posted: 28 Oct 2020 at 6:51pm |
Can't see where the leak originates but yes the spoiler is in the area where I have noticed some trickle stains on the wall. Even during a rain I cannot see any moisture anywhere but what ends up in the counter. Weird!
JR
Posted: 28 Oct 2020 at 6:57pm |
Welcome to the forum and congrats on your 179. I have experienced the same water intrusion problem on the slide side of the counter top of my 2019 179. I had the trailer in at the end of the season last year for some warranty work at the dealer where I purchased it (the work was replacing a side wall on the slide out because the exterior fiberglass had delaminated from the wall) but at the same time I told the dealer about the water coming in on the counter top after a rainstorm and the water was running down the wall from the interior bottom frame of the window. They felt that the rear window gasket had not been installed properly. They took the rear window apart and sure enough the gasket was what was causing the leak. They repaired it under the warranty work. Don't know how big a job it is or if it can be done by an owner or not (the need for special tools). You may want to do some youtube investigations. That is where I would start with your water leakage.
Jay
179/2019
Posted: 28 Oct 2020 at 6:59pm |
Spoilers are a source of leaks. Many of us have eternabonded our spoilers up sides and across tops to eliminate leak issues. Takes a bit of effort. If you decide to go that way, post, and you'll get plenty of advice.
Posted: 28 Oct 2020 at 7:02pm |
+1 to JR, did not see that post prior to my reply.
GodsPod
Posted: 28 Oct 2020 at 7:04pm |
Thank you Jay. It could well be the culprit. I have noticed some rippling of the back wall board beneath the window. Good advice. Will look into it. Thanks
GodsPod
Posted: 28 Oct 2020 at 7:08pm |
Mike, Thank you for your help. Is eternabond a product or a technique? Not familiar with much of this be terminology.
JR
Posted: 29 Oct 2020 at 8:20am |
Eternabond is a product "type" of sticky tape that is used for RV roof repair and other things on the exterior of the trailer. Does a good job sealing up the spoiler above the back window.
Jay
179/2019
GodsPod
Posted: 29 Oct 2020 at 6:50pm |
Jay, for the spoiler sealing best results would I need the 2" or 4" Eternabond tape and what is the best prep for the surface area? Are the Eternaclean and Eternabond Spray worth the money? I would like to share a photo of the sealant currently used on it. Is there a way to do that on the forum?
Bob
