Front window broken |
Page 12> |
J&BinAZ ![]() Newbie ![]() Joined: 17 Jun 2022 Location: CENTRAL AZ Online Status: Offline Posts: 8 |
![]() ![]() ![]() ![]() Posted: 21 Jun 2022 at 1:52pm |
campman ![]() Senior Member ![]() ![]() Joined: 26 Mar 2021 Location: La Salle, MB Online Status: Offline Posts: 209 |
Lots of incidents like this since FR decided to put a big window on the front - do a search on this site or on the interweb, lots of reports and one just recently here that you may find educational) as to others experiences.
I know of three types of windows they have tried...yours, which sounds like tempered glass and a bad idea. Then I heard the next attempt was a dual pane unit. These were reported to fail as the rpod isn't rigid enough structurally and the seals would break and lead to fogging between the panes. The third is what is on our 192, a tinted plastic type which seem to work as designed as long as they are installed properly. I would suggest to go through your rpod dealer to see if they will warranty it as it was a bad type of window to install. Some who have gone through the process with FR have had successful conclusions, others not so much. Gotta give it a try though, I am thinking. Wait times can be long for parts etc as we have all experienced by now. When my 192 front window leaked due to a bad installation, I just got a piece of thick clear plastic used in home construction for vapour barrier. 9 mil thickness if I recall correctly. Cut it a bit bigger then the window and used a good tape to tape all the way around it to keep any water out till I could get it in to be repaired. Once you remove the tape, have some goo-gone or similar product to help take any remaining tape and residue safely off your trailer front. You don't want to damage the surface or finish. Good luck, and let us know how things work out. Hopefully for the best! Andy |
Andy and Laurie
'16 F150 5.0 4X4 w/factory tow pkg '21 RP192 "If the women don't find you handsome...at least let them find you handy!" Red-Green |
One more note, your trailer is still under warranty, so definitely try to get it repaired through Forest Rivers warranty so you don't have an insurance claim against you, and it shouldn't cost you anything out of pocket.
Another thing, if you need to tow it with the plastic over the window hole, try to reinforce the plastic from the inside, maybe with a stout piece of cardboard that is supported from the inside of the window frame. Or, as I suggested in another thread where their window shattered, take out the window completely and have a shop fabricate a piece of aluminum or other product to permanently affix over the hole, fill, insulate and finish it from the inside and never have a problem again with it! Hope this helps, and good luck. Andy Andy |
Andy and Laurie
Thanks for the info. I'll check into the vapor barrier. I currently have a piece of reflectix covering it and held down with several layers of good waterproof tape, but not sure if it will withstand our Arizona monsoons. I also think it is a design flaw, even though we have enjoyed the light inside. I will give FR dealer a call. Thanks!
Grand Canyon State rules!
I like that last idea about the aluminum fabrication. If the window takes too long to arrive, I will probably go that route. Can't have the rpod sidelined for 3 months during prime mountain camping season!
There is a recent thread here that shows what one person did when he found extensive water damage at the back of his trailer, plywood work was wonderful!
Andy and Laurie
Yeah I saw that one. Don 't want to go to that extreme. Looks like he carved that rpod from a single piece of wood...
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
I'm surprised no one has suggested getting a lexan window fabricated. lexan is very strong, and I think it's what they use on fighter jets.
I have heard of lexan, but who does such fabrication? I am having a tough time just getting the insurance company to set me up with an rv glass installer. Thanks.
I've suggested polycarbonate several times. Lexan is just GE Plastics' brand name for it. Regardless of brand, it's good stuff for this application as it won't break. You can scratch it so use care while cleaning; flush first, use a sift cloth, and use straight line motions. Circular motions can cause swirl marks which draw your eye.
You can use normal saws to cut it, not a problem at all. Easy DIY. You can get pretty much any thickness you want so get close to the same thickness as the the glass youre replacing so the seal will engage properly. |
Page 12> |
