RPOD Security Tips ? |
Post Reply | Page 12> |
marshwatcher
Senior Member Joined: 14 Jan 2011 Location: Sunny FLORIDA Online Status: Offline Posts: 127 |
Topic: RPOD Security Tips ? Posted: 29 Jan 2011 at 11:28am |
We are new to RVing with our new RPod to be delivered shortly. I have been looking at all manner of devices that are meant to secure the hitch. Are there recommendations anyone would care to make? Also, I read that the storage compartment locks on RV's may be universal and need upgrading or changing. Any recommendations? We have an open bed truck as the tow vehicle and wonder if anyone has solved the storage/security issue for a truck with something less than a topper or Tonneau cover? Finally, has anyone used the LED battery powered motion lights for the outside of the Pod?
While I understand that if thieves want to strike, they will. I just like the idea of slowing them down as much as possible and making them work for it! Any and all replies are much appreciated in advance! |
Guests
Guest Group |
Posted: 29 Jan 2011 at 12:09pm |
Most of what you said is true regarding the locks - they are not very secure at all and the keys are common. In the case of storage compartments, you don't even need a key. Just stick a screwdriver in the lock and turn the whole assembly. The door locks are simple "wafer" locks that are easily picked. However picking takes too much time for a thief. It's quicker to just pry the door open...who cares if the door frame gets bent?
You are right, the most you can hope for is to slow them down and make them work a little bit. I don't know of any practical way to answer your question that would leave your Pod visually pleasing. For the tongue, I just use a regular padlock.
I do use a lock on my receiver/ball on my truck. They are very quick/easy to take, several dollars to replace, and you can't leave the campground without 'em!
PS - I'm an ex-cop and also an ex-locksmith.
I wasn't quite as handsome back then as I am now!
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1218 |
Posted: 29 Jan 2011 at 12:43pm |
For the storage compartment doors I left the original locks that work with a key on. But the turn lock without key I replaced with a small combination lock, I think it was called a cam lock. If you go to the rpod nation web site you could find it useing the search function or check the modification posts. With both locks on each side it less likely to be pried open. But if a thief wanted too, they could pry it open useing a tool. We use a hitch lock while being parked in our driveway. We have insurance that is our last protection. David and Danette
rabuol
Newbie Joined: 31 Aug 2010 Location: Northern Ontari Online Status: Offline Posts: 10 |
Posted: 29 Jan 2011 at 3:14pm |
Hello Marshwatcher,
Here is what we replaced the locks with:
and this is what we use as an adjustable hitch:
http://diversi-tech.net/Hitches%20Page.htm no locking pins...
and this is what we lock our trailer with:
http://www.bumpkeyshop.com/Master-Bump-Key/ notice that it's bump proof
Lou
Lou
rabuol
Posted: 29 Jan 2011 at 3:18pm |
Update:
the bump proof Master lock is used on the receiver/hitch...not he door
http://www.bumpkeyshop.com/Master-Bump-Key/ Lou
Lou
Posted: 29 Jan 2011 at 4:27pm |
You can also add a coupler lock, which effectively fills up the cup where the ball resides. However, thieves have been known to just drive up, wrap the security chains around a few times and drive off even with one of them in place. Another option is a wheel lock, which will immobilize the wheel. |
TerryM
Posted: 29 Jan 2011 at 4:53pm |
Then add locking lug nuts too. Terry |
marshwatcher
Posted: 31 Jan 2011 at 10:01am |
Great suggestions! One thing I did find out is that camping safety statistics are hard to come by. However, the instance of "serious crime"(not specifically defined in the information) is 1 in 25000.
I believe it is pretty safe out there but maybe the very best defense is getting to know your RVing neighbors and watching out for one another! I just despise thievery! I know it happens but it makes me |
marshwatcher
Posted: 31 Jan 2011 at 10:05am |
David,
Maybe you should give a safety seminar at the next RPOD get together. HMMMMM...don't you love it when people volunteer you for something. |
Outbound
Posted: 31 Jan 2011 at 11:48am |
I've heard rare examples of theft of lawn chairs and bicycles while a trailer is setup for camping, but thats it. I've found campgrounds in general to be very safe and other campers tend to keep a watchful eye. Although I've changed locks and added padlocks (coupler hasp and receiver pin) and a coupler lock, there's really only so much you can do. When it comes down to it, the trailer and contents are insured should thieves come calling. -edit- Actually, we got into a huge fight over locking the trailer door. While we were camping, I was locking both locks on the trailer door (the handle and the bolt). Aparantly, this was beyond the pale; I was told (screamed at) that I was far too paranoid. In retrospect, perhaps I was overdoing it. We only lock the bolt now and things are much more amicable.
