GlueGuy
Topic: Air in tires Posted: 28 Mar 2018 at 8:22am |
I use air from Neptune. It's is mostly helium and hydrogen so I am able to lower the weight of the trailer a little and the tires float better. |
UPS charges must be astronomic.
lostagain
Posted: 28 Mar 2018 at 9:13am |
furpod is right, I run load range D tires and they need 65 pounds. And the gas is a little expensive. I get it from a trading post in Beaty NV, just west of Area 51. Gus, the owner, also sells remnants and pieces of alien space craft. He gave me his assurances that the Neputne air is legitimate, so I believe him. And yes, Stephen you need to be careful about flats, but remember the volume of air is much less and you're driving away from it, likely at 60 mph, so all you get is a little boost, kind of like an after burner on your Pod.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Hayduke
Posted: 28 Mar 2018 at 9:58am |
Originally posted by riotkayak284
65 LBS? Wow my POD says on the label on the side, 50 LBS.... Sure you are not over-inflating? The verhicle sticker is the correct inflation pressure...
https://info.kaltire.com/the-right-tire-pressure-why-the-maximum-isnt-the-best/
Trailer tires are much different than passenger vehicle tires, and should be run at the max pressure. Which would be different if the pod tires are changed to a different load range. Also, on passenger vehicles, the sticker on the car is the proper pressure only when dealing with the oem tires and stock vehicle weight. If any of the variables change, then the proper pressure also changes.
2012 177 HRE
2017 Tacoma Double Cab
codycountry
Posted: 28 Mar 2018 at 12:25pm |
I use high altitude air from the Rocky mountains. It is pollutant free and has a slight pine scent. Because it comes from higher altitude it is lighter since it doesn't have as much oxygen in it as sea level air does. Am hoping someday to get some air from near the Area 51 boundary fence and see if the Pod seems to float behind the truck.
Seriously though, if I could get nitrogen, I would. It is unaffected by heat and cold. When the highways and air temp gets really hot in July and August I see a lot of blown tire pieces laying along Interstate 25-- from tires that heat over-expanded and blew up. Nitrogen solves that.
Posted: 28 Mar 2018 at 6:37pm |
I have a 2016 truck with Nitrogen in the tires, I also live at the intersection of 3 major interstates, 65, 24 and 40. I have a factory installed TPMS. I will tell you my pressure varies with heat and cold, not as much with air but still measureable. Blow outs are not solved by what fills the tire. Blow outs can be blamed on over pressure, but a major heat source is under inflation. OTR trucks can have both regrooved and recapped tires, only buses are regulated to have virgin tires on the steering wheels. The material you see on interstates primarily comes from tire failures from OTR vehicles. Granted it can increase during summer months as the road surface has more heat. Nitrogen has nothing to do with this. Once again, air, what we breath and fill tires with is 78% Nitrogen.
GlueGuy
Posted: 29 Mar 2018 at 12:05pm |
Originally posted by mcarter
Nitrogen has nothing to do with this. Once again, air, what we breath and fill tires with is 78% Nitrogen. |
Agree. The hype about alleged benefits of nitrogen filled tires far exceeds the actual benefit. Personally, I feel it is a waste of time and money.
