Gadgets |
Post Reply | Page <12 |
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Topic: Gadgets Posted: 03 Aug 2019 at 7:19pm |
I'm like StephenH; I have an OBD bluetooth transmitter so I can monitor some other parameters.
As for the WDH setup, I'm happy with figuring it out with a typical load (via scales), and going from there. If the tongue weight is shifting while you're underway, you got some other serious issue.
Tars Tarkas
Posted: 03 Aug 2019 at 9:36pm |
There are OBD splitters that will let you plug 2 things into your ODB port. From what I've heard, they may not work for everyone or for all devices, but I've had 2 things plugged in and working fine on my truck for several years. Here's one for example: https://www.amazon.com/Outzone-Splitter-Extension-12inches-Vehicles/dp/B07V7DPF9F/ref=sr_1_6?crid=HR21RPKOFZH8&keywords=odb+splitter&qid=1564886032&s=gateway&sprefix=odb+s%2Caps%2C406&sr=8-6 TT
FJ Cruiser |
Posted: 04 Aug 2019 at 5:37am |
You wouldn't really need to leave the device connected anyway. Just use it once when you hitch up and then remove it. No need to connect it again unless you significantly change your TV or trailer loads. For a travel trailer that's pretty rare, once you know what it weighs under a couple of different conditions (mostly different water loads) you really shouldn't need to use it again. I can see the device being a lot more useful for a utility trailer if you're hauling a wide variety of things around, or if you have several different trailers. Assuming its accurate of course.
podwerkz
Posted: 04 Aug 2019 at 9:35am |
Somebody buy this thing and use it to get the readings, then drive to a certified scale and I want to know how much it is off. Cuz it will be. |
Posted: 04 Aug 2019 at 3:59pm |
+1. That would be a great experiment to do if anyone has some spare money and time on their hands.
