  New Posts New Posts RSS Feed: One Battery..or Two?
Topic ClosedOne Battery..or Two?
Itinerate Pod View Drop Down
Direct Link To This Post Topic: One Battery..or Two?
    Posted: 06 May 2017 at 7:58pm
Originally posted by Pod People
For what it is worth, the GC2 batteries are generally available at lots of retail stores including Sam;s Club and Costco.  We got ours at Sam's for about $120 each after turning in the old ones for the core charge.    the good thing about buying them from Sam's or Costco is that these stores are everywhere, so if you need replacements it is easy to find them .  The ones we bought have 115 Amp hours each (if I remember correctly).  Wire them in series and we have 230AH available.
Vann
Each battery would be 230 AHr @ 6V.  Two of the them wired in series, gives you 230 Ahr at 12V.
Two 12V batteries at 100 Ahr wired in parallel, gives you 200 AHr at 12V.
Jim & Kathy
Sadie, our canine companion
2017.5 RP 180 HRE
2006 Northstar Popup Truck    Camper
2017 Audi Q7, 2006 Dodge 2500 4x4 Diesel
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 06 May 2017 at 9:41pm
Two 12 volt batteries in parallel, double the amps, voltage remains 12 volts.
Two 6 volt batteries in series, double the volts, amps remains the same.
True 6 volt golf cart batteries ( TRUE DEEP CYCLE), offer MORE amp hours than a 12 volt RV/Marine battery. There are very few 12 volt TRUE DEEP CYCLE batteries on the market, and they cost a fortune.
I looked at (briefly) the lithium ion (iron) RV batteries, wow, sticker shock. They have some serious advantages over wet cell batteries. They can charge quicker, have very high discharge rates, can be fully discharged at their full rate until they give up (they are internally protected from being depleted too low, which hurts them), and they can be charged to 100% again with no sulfation/memory problems. They are also MUCH lighter for the same amp-hour rating as a wet cell. They do not out gas, making them good for inside installation.
They do get derated in colder temperatures, but all batteries do.
I'm currently looking at getting to Trojan T-105 batteries locally, because the Costo, Sams, don't carry a comparable battery, and shipping instead would be almost as much as the batteries themselves!! i think $200 each is not too bad for a price.
 My example:   (2) Interstate HD24-DP 12 volt batteries in parallel. The RC (reserve capacity) of these dual purpose (starting / "deep"cycle) batteries is 200 minutes at a 25AH discharge rate. That is double the 100 minutes of only one battery alone.
But two Trojan T-15 batteries in series at 12 volts, delivers 447 minutes @ 25AH. One 6 volt is 447 minutes @ 25AH. The two 6 volt batteries have more than double the reserve capacity, are only a little taller, and weigh a bit more, but have MUCH more energy density. And they can be more deeply discharged and last longer than the dual purpose batteries. Properly maintained (distilled water, and desulfation charge cycles when needed) can make them last 6-7 years. If you don't let your batteries get low on water, and don't deeply discharge them, they can last a long long time.
The downside. Up front cost. Takes longer the charge them to 100%. More tongue weight (which may not matter depending on tow vehicle).
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
