Sway Bars |
Post Reply | Page <123 |
Topic: Sway Bars Posted: 10 Mar 2017 at 8:18am |
One other item: Was this observed when the Pod was parked in the same location as it was when it worked properly? When level, my Equal-i-zer is pretty much even when hooking up the bars. However, in my driveway which has a little side-to-side slope, it is much as you experienced with needing to raise it up higher to connect one side than for the other side since I usually have the R-Pod leveled but the car is not.
lostagain
Posted: 10 Mar 2017 at 2:15pm |
I've noticed that the bar pressure varies on our Fastway E2 hitch depending on the slope of the parking area. One side or the other is under greater pressure and it requires raising the trailer a little more with the tongue jack. I just assumed that the variation in pressure was due to the TV and the trailer being a bit "twisted" from the unevenness of the ground.
SandD
Newbie Joined: 09 Sep 2014 Location: nc Online Status: Offline Posts: 35 |
Posted: 10 Mar 2017 at 6:04pm |
Swapped the bars no good. Inspected the head ok.
Nothing moved or loose. Noticed the Dr side truck rear looked a bit low. I had broken my old pressure gauge but had another cheap one I used before we left. Bought a new gauge and checked all truck and camper tire pressure. Three truck tires off by 5 lbs and one by 10. Camper tires were at 62lbs. Threw the cheap gauge in the trash. New gauge new settings we are good. Thanks for all the help. |
There are two types of people in the world. Those who like RPODs and those who are wrong.
Rpodder 2014 RPOD 178 06 Tacoma Prerunner TRD |
Posted: 10 Mar 2017 at 8:11pm |
I'm glad you got it figured out. A good tire gauge is an investment worth making. Those cheap ones can really mess one up. I have a Slime Digital Tire Pump that I use. It has a built-in gauge and one can also set it for the correct pressure and it will stop when that pressure is reached. Despite Amazon's page saying designed for 35 psi, it works fine inflating my trailer tires up to 65 psi (load range D tires).
SandD
Posted: 10 Mar 2017 at 8:56pm |
Still need to do the range D tires.
What brand did you get. |
Posted: 10 Mar 2017 at 9:51pm |
Carlisle. I got them at Discount Tire.
Carlisle Radial Trail HD ST205/75R14 105M D1 BSB |
Posted: 11 Mar 2017 at 7:05am |
X1
