Have You Done Any Mods? |
Post Reply | Page <1 4445464748 52> |
Puckett435
Newbie Joined: 28 Feb 2020 Online Status: Offline Posts: 1 |
Topic: Have You Done Any Mods? Posted: 09 Mar 2020 at 7:21pm |
I have a 2017 R-Pod 180 that has one of the small refrigerators and I would like to upgrade it to one that is bigger, like what they are putting in some of the newer 195/196s. I was wondering if anyone here has done that mod.
Cheri
Post Options Quote Reply Posted: 10 Mar 2020 at 10:07pm |
Hello Cheri and welcome! Unfortunately, it would be very difficult to replace the refrigerator. The space is limited. I'm not 100% sure about the 180, but isn't the refrigerator in the slide-out? It would not be possible to raise the exhaust vent higher. In the 179, the convection/microwave is above the refrigerator. I guess one could eliminate that and put a larger refrigerator in, but making sure it is properly vented would likely be an issue.
Post Options Quote Reply Posted: 11 Mar 2020 at 6:16am |
The other, much simpler option is to either get a high quality cooler or a good 12Vdc (compressor, not thermoelectric) fridge and locate it either in the TV or under the table. And, you can keep your beverages in it and place it outside during the day. We find that if we don't fill up the Dometic with beverages than there is plenty of room in it for a week's worth of food for two.
Pod People
Post Options Quote Reply Posted: 11 Mar 2020 at 8:10am |
I agree with Offgrid-we use a high quality cooler for most liquids and vegetables. leaving plenty of refrigerator space . Freeze half gallon jugs and put one in each end of the cooler and with careful usge they will last 5-6 days. I also made an insulated cover for the cooler which helps. Vann
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Online Posts: 2587 |
Post Options Quote Reply Posted: 11 Mar 2020 at 8:45am |
We got a Lifetime ice chest at Wally World for about $95, that is comparable to the high end ones, such as Yeti. With ice in repurposed Costco nut and candy plastic containers, we've been able to keep drinks and such cold for a week.
Olddawgsrule
Post Options Quote Reply Posted: 11 Mar 2020 at 3:10pm |
As far as I've seen most all of us have a cabinet over the Frig (wether space or microwave). If you can do without that space (or Microwave) you have a shot at it. With some effort and a jigsaw, you can open up enough. I don't recall the exact model, yet Dometic does make a larger that fits. I looked into this and really thought I would do it. Have to say... really glad I didn't.. It came down to, I won't have a frig large enough to do 'everything' I hope for. AND that space (no microwave here) is important storage (eye level) space. The Frig is big enough to get 'us' beyond the point of replenishing the 'fresh' stuff (greens only last so long, aye). The Freezer, I almost want to remove... yet we do use it (as small as it is..). We do run a separate cooler as well. That in my mind, is the way to go. |
marwayne
Post Options Quote Reply Posted: 11 Mar 2020 at 4:07pm |
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Post Options Quote Reply Posted: 28 Mar 2020 at 8:57am |
Nice job as usual!
Kup-Pod
Senior Member Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
Post Options Quote Reply Posted: 28 Mar 2020 at 4:53pm |
That is very cool!
If you don't mind me asking, what styrofoam did you use? Did you have to "seal" the surface of the foam? And did you put a drain in it or do you just wipe it out when you're done?
Sorry for firing the questions, but I definitely see a mod in my future? :-) |
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
marwayne
Post Options Quote Reply Posted: 28 Mar 2020 at 6:02pm |
I used the blue Styrofoam ( R 8 ) then covered it with laminate siliconed the corners. No drain we put the ice in a tub and what ever is wet we wipe it up
