Have You Done Any Mods?
 Post Reply Post Reply Page  <1 3233343536 52>
683 [81.41%]
10 [1.19%]
134 [15.97%]
10 [1.19%]
2 [0.24%]
You can not vote in this poll
Webstas View Drop Down
Post Options Post Options   Quote Webstas Quote  Post ReplyReply Direct Link To This Post Topic: Have You Done Any Mods?
    Posted: 08 Sep 2014 at 1:28pm
+1 for me too.
Is that the 2015 RP172 ?
jeeperic View Drop Down
Post Options Post Options   Quote jeeperic Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2014 at 3:51pm
Would like to open the area above the stereo for books, CDs, DVD, what have you. Does anybody know what's behind this panel?
That's the power button..press it.
Turn it all off.
Go outside!
'14 RPod 171
'09 Jeep Wrangler JK (mine)
'14 Dodge Ram 1500 4x4 (hers)
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 2:42pm
  On our 171 we mounted the spare in front beside the propane tank it made a big difference with the tongue weight.
2014 Ram 1500 Quad cab
Harry View Drop Down
Post Options Post Options   Quote Harry Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 7:40am
Good point.
 I forgot about that - moving the spare was the first thing I did when I got my 'pod home.    The spare is attached to the bed board.  Not only is it a lot of weight back there, but it makes for a very heavy lift when setting up the "bedroom".  I simply put it in the back of the truck.
2013 R-pod 176T
TV: 2013 Honda Ridgeline
3.5 L 4WD
RCU View Drop Down
Post Options Post Options   Quote RCU Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 11:34pm
Recreational Care Unit (RCU)
mtbmitch View Drop Down
Post Options Post Options   Quote mtbmitch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 10:22pm
moving spare tire to front of trailer instead of hanging off the back is another way to transfer the c.g.
enjoy the fresh air
JayPod View Drop Down
Post Options Post Options   Quote JayPod Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 1:55pm
My 177 swayed a bit until I got the right hitch height. It rides best with a bit of a rake angle towards the TV. Since then, all was well.
2014 177
2014 Audi Q5 TDi
2013 Ford Escape EcoBoost
cmrb View Drop Down
Post Options Post Options   Quote cmrb Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 11:45am
On the 2014 177: took old cargo nets from pickup truck and strung them across storage area under bed secured with teacup hooks. Keeps 2 containers with clothes from sliding during travel. Also strung a second net in front of the dinette, securing to the faces of the seats. You can store a lot of miscellania there and it adds weight to the front of the trailer (specifically: 2 laptops, a Dreml kit, toiletries bag for showers. a medium sized container with paperbacks. Any help? Thanks. CMRG.
cmrb
Post Options Post Options   Quote mtbmitch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 11:22am
how about some better shocks for the TV.
enjoy the fresh air
Post Options Post Options   Quote Harry Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 9:25am
My (unprofessional) opinion would be a "no", especially if your GVW exceeds the limits specified for tow vehicle and trailer.   Suspension geometry on a vehicle won't permit a "teeter-totter" effect; adding weight to the front in an attempt to balance it will simply make everything lower.  Basically, you would have to add weight ahead of the front wheels; it's simply not practical.
If your tow vehicle's back end is getting too close to the ground, then all I can suggest is to reduce the tongue weight, or install an equalizer.  But even an equalizer is not necessarily a given fix.  It transfers weight from the back of your TV to the front of the TV and the trailer wheels by raising the back end of the TV.  You might be able to pack a lot of weight in the back of your 'pod to reduce tongue weight, but that's not a good idea because you might end up overloading the RV.
If it's a truck or SUV you're using as a TV, then you might also reduce the load in the back of the truck, and make sure the truck suspension is stiff enough to support the loads you are putting on it.
You should also check the "traveling" weight of your trailer, and the weight on the tongue.  Usually the tongue weight runs around 10% of the trailer weight.  A heavily loaded trailer will naturally have a high tongue weight.  If you travel with a full water tank (which on my Rpod is located in the forward end of the RV), emptying it might be the first change you need to make to lighten things up.
To make a long story short, reduce your weight, and examine how your TV and RV loads are distributed.
2013 R-pod 176T
3.5 L 4WD
2013 R-pod 176T
3.5 L 4WD
