Generator - Event Date: 14 Jul 2017 |
Post Reply | Page 123 5> |
Plantguy
Senior Member Joined: 29 Mar 2015 Location: Calistoga, Ca Online Status: Offline Posts: 102 |
Calendar Event: Generator Posted: 16 Jul 2017 at 1:44pm |
Hello Poders,
I am in the market for a generator. I want a quiet one. I know Honda seems to be the generator of choice. I was hoping to spend less than $1,000. I would also be interested in a propane powered generator but my main requirement is low noise. 2000 watt. Will run both 12v and 110 systems. Any help is appreciated. Ken, the plantguy.
Life is too important to be taken seriously!i
Guests
Guest Group |
Posted: 16 Jul 2017 at 2:28pm |
I have a Champion 2000 watt inverter generator and have been pleased with it. They can be had for around $500. It seems to be as quiet as the Honda. Mine will not run on propane, however. |
funks
Groupie Joined: 05 Nov 2014 Location: CALIF Online Status: Offline Posts: 98 |
Posted: 16 Jul 2017 at 2:38pm |
I have two 2000i generators. A handa and a honeywell. Both run great. The honda starts on the first pull and the honeywell always needs about ten pulls with a little help with starting fluid. There both quite running. honda about $1000 honeywell $500. honda is lighter by about 10lbs.
BobHerring
Newbie Joined: 16 Jul 2017 Location: Lakeland, FL Online Status: Offline Posts: 1 |
Posted: 16 Jul 2017 at 3:26pm |
Hey Ken:
I'm not yet an Rpod owner, but we are semi-seriously thinking that it will be our next rig. We're now on our third pop up camper, a Forest River Mac. I bought a Honda eu2000i generator last year before we did a 15,000 mile from FL out to WA state and all in between. Needed it when we were off-grid, to recharge the pop up battery mainly because I use a CPAP machine at night. Bottom line: the Honda is a terrific generator. It runs a long time on a gallon of gas. It is VERY quiet, with a "normal" setting, and an even quieter "Eco" setting. It starts up easily and dependably. It charged the battery up with no issues. It is worth $1000.00. Next week we are going on a 2-month road trip up the Easr coast. I upgraded the battery from a 100-amp hour starting battery to two 100-amp hour deep cycle batteries running in parallel. I expect this to work well. We will see. Hope some of this info is useful to you. Bob
Bob
TheBum
Posted: 17 Jul 2017 at 12:14pm |
The Honda generators tend to handle power surges better than cheaper ones. The typical Champion 2000W has an 80cc engine, but the Honda EU2000i has a 98.5cc engine.
Mtn Ascender
Newbie Joined: 07 Mar 2017 Location: Wisconsin Online Status: Offline Posts: 12 |
Posted: 17 Jul 2017 at 12:26pm |
So I recently sold my Honda eu2000i after 13+ years of minimal use. It was barely just too small. I needed another 300-500 watts.
I found this unit from Westinghouse. Not much info out there on it as it is a new model. But it appears very similar to the Honda in almost all aspects. It appears to work pretty decent. Is within a db or 2 of the Honda and has similar run specs. I've barely run 1 tank of gas through it but it seems to function quite nice. http://apelectric.com/westinghouse-igen2500-2200w-portable-inverter-generator/?gclid=CP7S0P3pkNUCFYE2gQodu84Jcw |
Capt Kidd
podders Helping podders - pHp Joined: 18 Aug 2015 Location: Chico, CA Online Status: Offline Posts: 212 |
Posted: 17 Jul 2017 at 2:41pm |
I have a 179 and the Honda 2000 wouldn't run the AC so I bought a Yamaha 2400 which will./ I paid $1295 plus tax and am very happy with it.
The Pirate's Pod
Mtn Ascender
Posted: 17 Jul 2017 at 6:28pm |
Guys if you're too lazy to click on the link I posted the Westinghouse can be bought for $550. Not $1000 or $1295 and it does just as much as the more expensive ones do.
Posted: 17 Jul 2017 at 6:43pm |
I am not lazy but in tune. My Generac does what I want it to do, and I understand the limitations. So I am happy. I agree you can purchase bigger happy, but I chose not to do that, I chose a genset I can maneuver and meets my needs. Lot of products out there. Mine does what I need.
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 17 Jul 2017 at 10:24pm |
Your link doesn't work or my phone is broken |
