YODT ![]() Newbie ![]() Joined: 17 Feb 2017 Location: Texas Online Status: Offline Posts: 31 |
![]() Posted: 18 Jul 2017 at 2:44pm |
First trip in our new 179 last weekend. The door was incredibly hard to open - sometimes I had to get both thumbs under the latch and pull super hard. My wife couldn't get it open at all a few times. And of course sometimes it opened as easy as can be. It wasn't locked either, though I'm often known for dumb things like that!
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
I am having the exact same issue with my new 179. I think it must have been fitted in Winter and now with the heat the door has expanded and is sticking. All I can think of is to spray some silicon lube at various points. Let me know if you come up with something better.
Bugout ![]() Senior Member ![]() ![]() Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
The locks stricker plates are adjust sound like you to let them out a little
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
M&M ![]() Groupie ![]() Joined: 19 May 2016 Location: Middletown, NJ Online Status: Offline Posts: 80 |
We had the same issue with our 179. Finally loosened up after a month or so...
2017 179 "Big Sexy"
2012 Honda Pilot |
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4512 |
We had it happen when we were in Maine, a couple of blasts of WD-40 did the trick
dr2428 ![]() Groupie ![]() Joined: 13 Aug 2016 Location: Nebraska Online Status: Offline Posts: 70 |
I have had that issue twice on my new(last August) 179, the door opened and closed smoothly at the dealer. In my case I was too aggressive dropping the stabilizers and it tweaked the frame just enough to cause the door to stick. It just happened again this past weekend but I remembered, raised the stabilizers back up, then back down appropriately and problem solved. Give it a try, may work.
2017 RPod 179
2018 Chevy Colorado Z71 4x4 |
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
+1
rawest50 ![]() Senior Member ![]() ![]() Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
It happened to me once. What I found my rear stabilizer was barely touching the ground. I guess it allowed the Pod to sad ever so slightly at that corner. Run the stabilizer down and all problems fixed. I make it a point to go around and check all 4 stabilizers a second time.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. ![]() |
Also check to make sure the screen door hinge screws are all the way in. Our 179 was almost impossible to latch from the inside before I ran those screw in the rest of the way.
