  New Posts New Posts RSS Feed: PahaQue Visor Awning
Topic ClosedPahaQue Visor Awning
backin15 View Drop Down
Direct Link To This Post Topic: PahaQue Visor Awning
    Posted: 06 Aug 2017 at 10:03pm
Awning looks nice! That one gives a lot more shade than the visor.
I would post a pic of the visor but Photobucket doesn't seem to like me anymore. I am going to have to find another hosting site.
2015 179
2013 Xterra Pro 4X
chiman View Drop Down
Direct Link To This Post Posted: 06 Aug 2017 at 1:45pm
Have new 180 with the new type awning.  Prior to this trailer I had a 178 and used the setup in the pictures. A couple of helpful tips:
1. Make sure you coat the hole where center pole fits into the trailer (or fits into awning can't remember which but they point this out in instructions) coat with the sealer they provide or get your own so that when it rains water does not drip from the hole.
2.  When it rains make sure adjust the entire awning so that the awning is very taut and top slopes some from center to sides as the awning has a problem with water pooling in spots unless sloped and made taut.
Other than the above two points, I loved the awning as it provides a lot of covered space and privacy as needed.
Chiman
2017 180 "Frog" towed by 2017 Toyota Tacoma with co-pilot "Willow" a 80 lb Labradoodle
Polly View Drop Down
Direct Link To This Post Posted: 06 Aug 2017 at 1:12pm
Can you attach a picture of Rpod with awning?
Bugout View Drop Down
Direct Link To This Post Posted: 06 Aug 2017 at 9:00am
Nice set up
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Wood River Pod View Drop Down
Direct Link To This Post Posted: 05 Aug 2017 at 11:50pm
Good to hear that you like the PahaQue Visor.  We thought long and and hard about the visor or the awning.  We ended up going with the PahaQue Awning and we love it.  The sides can be rolled up for better air circulation or lowered for rain or wind.  We had the front side down for privacy and the back side open.  Set up is easy.  Basically feed it into the keder rail and then feed the pole though the front sleeve and lock in.  Pound in your ground stakes and attach the guide lines.  Your all set in 10 min.  Just like setting up a tent.  This trip I did it all on my own while the fam took the dog on a hike.  It was tougher alone, but it can be done.  It provides great shade and protects camp in bad weather.  We used it down at Zions over spring break.  We were able to fit a picnic table underneath and still had room to move around.  Luckily I have not had to deal with PahaQue's customer service, but it's good to know that they'll be helpful if I do.  We bought ours through https://rvsupplyshop.com/.  The had a sale last November that I couldn't pass up.  Keep your eye out for deals.
As far as I can tell, this awning is similar to the r-dome, but without the full enclosure, which is what we wanted.  We wanted shade, not necessarily another room.  If a shade awning is what your looking for, that I highly recommend this product.
Thanks
Jeff
Smith's in Hailey
Early 2017 179 HRE
Wood River Mods
Direct Link To This Post Posted: 05 Aug 2017 at 12:12pm
We missed not having an awning a lot more that we though we would, so looked at some options. Our dealer said he could install one for $1,000, a heavy and expensive option. We looked at Rdomes, but they are still expensive and bulky. I discovered something called the Visor by PahaQue, which looked like a good compromise.
When they went on sale at Camping World, I ordered one. I was a bit worried though, as the PahaQue site lets you chose the model of your Rpod and Camping world only has one to chose from, but between the lower cost than the PahaQue direct price and free shipping I saved about $50, so I thought it was worth the risk.
When I received it, I was quite pleased. It is very light at less than 10 pounds, and comes in a carrying bag so it is protected and keeps the poles from wandering off. It is small enough to store in the back of the wardrobe or in the cabinet by the door. I did have two disappointments though when I went to set it up. First, the directions are not very good and the pictures are impossible to see, they are black and white and have been copied too many times. Second, the fiberglass poles were missing. Naturally, it was Friday and after business hours so they were closed when I called. I left a message explaining the situation with my name, address and phone number. I brought my receipt to work with me Monday expecting a "proof of purchase required" call or "you will have to deal with Camping World". Instead the call I received was very apologetic and I was informed the poles were on their way and I would receive them in a couple days. Great customer service!
That weekend we used it for the first time. Setup was fairly easy, the fiberglass pole is threaded through a pocket on the outside of the visor. This is a two person job, and because of the tension on the rod getting the end into the pocket it is supposed to rest in was difficult. The visor then slid into the Keder rail with little drama, and I was pleased to see that the width was perfect and it filled the rail end to end. The visor is them supported by two poles adjustable for height, and two tie downs. Both go into the lower Keder rail. We found having the poles one notch down from fully extended gave the best shape. It looks cute too, like the visor on a ball cap. We saw a lot of people pointing and smiling.
The awning worked well, and tolerated a good wind with no worries. We were facing dead South so it did not provide a lot of shade, and it did not rain so I can't comment yet on how it will hold up in a storm. Because of the shape I think it will do ok.
My biggest complaint, is the attaching point for the left support pole is dead center in front of the door. Putting the pole close to the door for best support means dodging it with your head when entering the camper. To avoid this, the pole needs to be at a considerable slant. The angle did not seem to be a problem for it though. I do wonder if I had ordered one directly from PahaQue and specified the 179 if the support location would be different. I am thinking of experimenting with moving it a bit, but I am thinking if I open the spacing between the two support points it may weaken the span though.
Overall, I am very pleased with it. Is it perfect? No, but the combination of low price, light weight and compact packaging make it a winner. Throw in the terrific customer service and lifetime warranty, and it gets two thumbs up.
2015 179
2013 Xterra Pro 4X
