First timer questions |
Post Reply | Page <123> |
Author | ||
rawest50
Senior Member Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Topic: First timer questions Posted: 13 Aug 2017 at 2:17pm |
I saw a review and the poster said you can raise the unit about 12". |
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. |
Posted: 11 Aug 2017 at 9:21pm | |
I got our Oxygenics when it was on sale at Camping World. It is possible that there is a difference in ones made for RV use and ones made for home use. We have had one at home for years, and while the one in the R-Pod isn't as powerful, it is an improvement over the stock shower head, at least when the water pump is running.
spydie
Senior Member Joined: 25 Jul 2017 Location: New Mexico Online Status: Offline Posts: 159 |
Posted: 11 Aug 2017 at 12:18pm | |
My experience with the Oxygenics shower head was just the opposite. With the on-board pump it couldn't produce a good spray like the factory head, and that indicates ONE thing...it uses more water (instead of less like it's advertised). If I can get a better spray with the factory head and low pressure, and very poor spray with the Oxygenics, that sorta speaks for itself as to the amount of water it will use. Your mileage may vary! LOL
Actually the Bal leveler presents no problem on the sidewalls of the tires and that's not even a problem worth looking for. If you install it correctly (with the pads in the center of the tire) you'll not see any excess pressure on the sidewalls and they've been around a lot longer than the Anderson leveler (which still requires one person to drive the vehicle and one to make sure it's level. The Bal leveler only requires one person) and my Craftsman 20v drill on the low-speed (power) setting has lifted much larger trailers than an R-pod. Just make sure you are using the right tool for the right job. But again, your experiences and mine are completely opposite so buyer beware. I know I've seen several posts on many different forums about people that like the Oxygenics, but not everyone does. I've talked to several people that returned theirs as I did. But whatever floats your boat! (smile)
2018 R-pod 176
2017 RAM 1500 5.7L Hemi |
Posted: 11 Aug 2017 at 10:48am | |
OTOH, I found that our water pump delivers a better spray from the Oxygenics shower head than when hooked to city water through the pressure limiter fitting. When I tested it at home with the pump, I had a good shower. My wife complained that it was inadequate when we tried it on a city water hookup in a campground.
The Andersen leveler is very easy to use. The BAL leveler on my 179 is simple, but takes a lot of work to crank it up. I tried my power drill/driver, but it did not have enough torque to raise the 179. It does go higher but the thing I don't like about it is that it is tilts as it raises which is putting more pressure on the outside of the tire and sidewall the higher it is raised. If the supports for the tires swiveled so that the tire would be supported evenly across the tread, it would be much better. Unfortunately, that would also probably make it a lot heavier. It is already much more bulky and heavy than the Andersen leveler or the stacking block levelers. |
spydie
Posted: 11 Aug 2017 at 10:25am | |
Ha ha. Ok. It will crank up a lot more than four inches but my pod is in the shop trying to figure out why the refer doesn't cool as well with gas as it does with electric so I can't measure it right now
2018 R-pod 176
rawest50
Posted: 11 Aug 2017 at 10:22am | |
You read it before I changed the post. How high.
2017.5 RPod 179
spydie
Posted: 11 Aug 2017 at 10:14am | |
Not sure what that question is "how I can you level"?? I've been camping in a lot of places that are way off level. But that's dry camping. Campgrounds are usually pretty level
2018 R-pod 176
rawest50
Posted: 11 Aug 2017 at 10:10am | |
Looks good. How high can you level? Most sites I have camped on the side to side is pretty level. Font to back varies. |
2017.5 RPod 179
Posted: 11 Aug 2017 at 9:25am | |
I think the best way to approach accesories is to decide which ones make sense to you. For example I don't have a water filtration system because we carry bottled water to drink. I do have a pressure regulator and a white and green hose. use your judgement. The fluke volt alert is important. It can prevent electrocution due to a poorly wired site or a bad connection.
spydie
Posted: 11 Aug 2017 at 9:07am | |
I tried the Oxygenics RV shower in my Casita camper and didn't like it, so returned it. I know a lot of people recommend it, but my water pump didn't seem to have enough power to get a full spray. I suspect the people that like it are using city water and not dry camping? My factory shower head sprayed a lot better using my water pump.
That Anderson Camper leveler seems to work great, but you are limited to about a 4" lift. My favorite camper leveler is the Bal Light trailer leveler. Just use your drill that you use to drop your stabilizers and it's done in seconds: http://www.campingworld.com/shopping/item/bal-light-trailer-tire-leveler/21017
2018 R-pod 176
