Topic: R-Pod vs Vista Cruiser Posted: 20 Aug 2017 at 2:47pm |
Originally posted by CharlieM
Yup. From their spec sheet: 2847+1533-380=4000. That's how they figure it, and that's a recipe for a bent axle.
Whole industry does it that way. The belief that FR somehow is doing something new and unusual with Pods is wrong, even though people seem to think it so. All they did/do, was find an attractive package to do the same thing with.
CharlieM
Posted: 20 Aug 2017 at 2:12pm |
Posted: 20 Aug 2017 at 10:58am |
It looks like they may have gone to a 4000# axle but I don't know if it solved the problem. You might search around for reports, maybe on a Gulf Stream or RV.net forum. They really had a lot of unhappy customers.
| That's interesting. The 19ERD is ~~ 2847# empty, with a 1533# carrying capacity. If my math still works, that puts the gross weight at about 4380#. Seems like manufacturers like to push the boundaries on axle capacity? |
Nope.. remember, tongue weight isn't carried by the axle, and 10%-15% of 4380 is just about enough to keep the axle under it's load limit, design criteria.
Posted: 19 Aug 2017 at 11:30pm |
CharlieM
Posted: 19 Aug 2017 at 9:25pm |
Back in 2012-2013 when we were looking for our first trailer we looked at the 19 ERD. It is a very attractive floor plan in that it has the full rear dinette, a dry bath, and the walk around bed. HOWEVER, they were having an extreme problem with bent axles because they were using a single 3500# axle. It looks like they may have gone to a 4000# axle but I don't know if it solved the problem. You might search around for reports, maybe on a Gulf Stream or RV.net forum. They really had a lot of unhappy customers.
Posted: 19 Aug 2017 at 7:52pm |
Never heard of it before. Poked around on the net a bit, and they look like similar materials to an R-pod. They will be a little wider and heavier than a roughly equivalent R-pod. The 19ERD looks "similar" to an R-179. About 600-800 lbs heavier, but does not include a slide-out. May not need it, as the body is wider to begin with (which is why it's heavier). I like the walk-around bed. Don't like the arrangement of the stove. Like the dry bath.
Similar pricing. I might look at one to consider.
utmck
Posted: 19 Aug 2017 at 5:43pm |
Just went to the local RV store to look at R-Pod's and learn more about them and also saw the Vista Cruiser 19 ERD by Gulfstream and was wondering if there is a difference in quality between the 2 rv's. I really appreciate any info anyone can shed on this.
Thanks.
