Honda pilot |
Post Reply | Page 12> |
RMP
Newbie Joined: 13 Oct 2017 Online Status: Offline Posts: 11 |
Topic: Honda pilot Posted: 21 Oct 2017 at 4:04pm |
just got a 182g and a awd Honda Pilot to pull it. Seems to do fine .anyone else using a similar set up ?
CharlieM
Posted: 21 Oct 2017 at 4:13pm |
I pulled an RP172 with a 2010 4WD Pilot for a few years. Much lighter than the 182g. If you stay on level ground a low altitude you'll be fine. Mountain passes at altitude will be harder. My Pilot pulled the 172 up to 10000+ feet in the Colorado Rockies but i was in second, and sometimes first, gear. Just monitor your transmission temperature.
RMP
Posted: 21 Oct 2017 at 5:19pm |
Had a tran cooler put on. Hope that helps. Cause I go to the Rockies a lot
CharlieM
Posted: 21 Oct 2017 at 11:36pm |
Not sure what model and year Pilot you have but the 2010 4WD came with the trans cooler. You still should add a transmission oil temperature monitor such as the ScanGauge. Don't trust the idiot light.
https://www.amazon.com/ScanGauge-Automotive-Computer-Customizable-Real-Time/dp/B000AAMY86/ref=sr_1_3?ie=UTF8&qid=1508646777&sr=8-3&keywords=scangauge&th=1 |
PilotPodder
Posted: 22 Oct 2017 at 2:16pm |
I towed a 171 (2400lbs dry weight) last year with a 2014 Pilot 4WD that had the tran cooler. I also added a brake controller. It worked well, but I did have an E2 Weight Distribution Hitch and never hit the mountains. It was still just an okay towing experience, with lots of engine rev and low gas mileage. I think mainly because of the Pilots short wheel base it isn't great at towing. Also, you can't put too much in the back of the Pilot without lowering the towing capacity. Just don't pass up gas stations given the gas tank size! Here is a thread to read:
~PP
MadCity
Newbie Joined: 18 Aug 2017 Location: Madison, WI Online Status: Offline Posts: 14 |
Posted: 27 Oct 2017 at 4:10pm |
We have a 2008 Pilot AWD and tow a 176T with it. It works fine. I towed it back from the dealer 450 miles, mostly interstate at 75mph, without any problems. Of course you NEED a WDH/Anti-sway and the consensus is a Fastway e2. It's the one I use and it works swimmingly. I towed the trailer when I first got it about 10 miles down the road to a menards parking lot using a straight ball mount so I could install the E2 hitch in the parking lot. Those 10 miles were a nightmare. I can't imagine driving any distance without the E2. As far as gas mileage, I believe it was around 9mpg. Pretty dismal. But, the pilot is what we have and it's paid for and I don't want to buy anything else right now. The towing capacity of the pilot is basically what lead us to the light-weight R-POD. Also be prepared to spend your time in the right lane, especially up any noticeable incline. You'll get to the top without any worries, just expect it to take a little while longer. You definitely need a trans cooler as well. Don't even think of towing without one. I also installed a power steering cooler while I was at it, just for good measure. There is lots of debate on whether that is needed, but since I had the front end of the Pilot apart anyway, I added it. It was just a handful of dollars and a little bit of extra time to install. |
2018 R-Pod 176T
2008 Honda Pilot AWD |
Posted: 27 Oct 2017 at 7:06pm |
Limit your speed to 60 mph and you will go farther and your wallet will not be so empty at the end of the trip. You will also feel more relaxed when you get where you are going.
mjlrpod
Posted: 29 Oct 2017 at 1:53pm |
I was towing my 172 home this morning, and looked down in horror to realize i was driving at about 82 m.p.h. I had about 12 trips this year, and with each trip i get more and more comfortable pulling the pod. I almost dont even think of it anymore. I was pretty upset at myself when i saw that i was traveling that fast, and made sure i stayed at 65 or less after that. Staying at 60 - 65 used to be a given for me, I agree with that speed recommendation.
Leo B
Posted: 29 Oct 2017 at 2:02pm |
+1 with StephenH
Posted: 29 Oct 2017 at 11:12pm |
California limits vehicles with trailers to the double nickle.
