  New Posts New Posts RSS Feed: LOW POINT DRAIN CAPS
Topic ClosedLOW POINT DRAIN CAPS
TEDDY View Drop Down
Direct Link To This Post Topic: LOW POINT DRAIN CAPS
    Posted: 08 Nov 2017 at 10:18am
Just got my new 178 - and still love it!
What I don't love is the turkey designer who put the low point drains almost behind the driver-side tire under the slide-out! And then, the foully feathered creature that he is, used caps that take a wrench (two,, actually) to remove.
Took the drain caps off today to ensure the lines were clear - and one of them has no washer.
Someone, I'm sure, knows where to get drain caps? The washer that was in one of them looks like a sleeve, not a simple O-ring.
Teddy
Subzilla View Drop Down
Direct Link To This Post Posted: 08 Nov 2017 at 12:21pm
I probably need a new cap....have one that drips no matter how tight I screw the cap.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Direct Link To This Post Posted: 08 Nov 2017 at 12:27pm
Look to see if the "washer" stayed in the fitting, mine used to do that.
You can use a PVC threaded end cap from lowes etc, 1/2". Just buy a washer that fits down inside. I carry a few spares. You can also get them at any RV shop, about $1 each.
OR you can do something like this, which I did.. also from Lowes etc..
Valve
Direct Link To This Post Posted: 08 Nov 2017 at 12:45pm
Thanks, Furpod
I really like the valve idea.  I'm sure that some day I'm going to dislodge the fittings at the end of the plastic drain hoses by torquing them with a a pair of pliers!
Appreciate you input .....
Teddy
Direct Link To This Post Posted: 08 Nov 2017 at 12:47pm
I like the valve idea too! I have the same fear about over tightening with the pliers! Will put this on my to-do list.
Mark
Concord, NC
mcarter View Drop Down
Direct Link To This Post Posted: 08 Nov 2017 at 3:26pm
I have valve on my fresh water tank. Happy.
