rawest50
Calendar Event: new rpod 179 owner/ issues and concerns Posted: 30 Nov 2017 at 8:16pm |
Darn. We have had only one of all the problems you listed. Number 4 -WD 40 took care of the lock. Maybe be a lemon. That crap happen even on automobiles.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Jm179
Posted: 27 Nov 2017 at 10:27am |
thanks for the info on locks..hopefully dealer will adjust during warranty fix.
Posted: 24 Nov 2017 at 5:14pm |
They are adjustable. Mine were loose when I first bought Pod and allowed water leaks, adjusting locks fixed issue.
RobnCari
Posted: 24 Nov 2017 at 4:22pm |
With the basement storage lock issue I filed the sharp edges of the catch smooth. Much improved operation. As this is only our 3rd day with our 2018 179 no other issues have come up (fingers crossed). Good luck with your 179:)
2006 Toyota Tacoma 4WD AC
2018 RP 179
GlueGuy
Posted: 19 Nov 2017 at 1:49pm |
We were out checking some things on the Rpod this morning, and ran out the slide-out to look at some things. There was a small puddle of water under where the refrigerator/microwave are.
It was a little surprising, but we did just have a rain storm (over 2" of rain in about 12 hours) with wind gusts around 50 MPH. As it happens the Rpod is parked such that the slide-out was in the direction of the wind.
I suppose it's possible that there was/is some gunk on the gasket at the top of the slide-out, so I will check that later today, and treat the gasket with some protectant. FWIW, we use 303 Aerospace Protectant on the gaskets (and other things outdoors).
Jm179
Posted: 19 Nov 2017 at 1:26pm |
Thanks for response. I agree with you on the compressed air as being important if you are not fully recharging system with antifreeze. It would seem that you could either fully blow out system and selectively add antifreeze to plumbing components..or just drain h.w tank and all plumbing through low point drains and then add antifreeze to storage tank with some water and use trailer water pump to pump "pink stuff" through system. No need to blow down if you are pumping antifreeze through system I would think.
Jm179
Posted: 19 Nov 2017 at 12:59pm |
Great info..I did assume that winterizing with compressed air and antifreeze was probably the most conservative approach to prevent any trapped water in pumps/filters and valves from doing damage. I have talked with people in rv campgrounds about their experiences with their vehicles and the general consensus is that you better be handy with tools to address issues that come up during trips. Even spoke with owner of Winnebago diesel pusher who had his hydraulic slideout fail in Alabama. He had a 45 day wait for repair to be done. Winnebago covered cost including hotel but still a hassle. I have been told also that you have to be persistant with warranty repairs as rv companies sometimes are leaning on rv dealers to make the repairs. Not sure if the rv dealers are reimbursed by manufacturer on this. Bottom line is you get what you pay for and rpods are not that expensive when compared to Airstreams or others. I have looked on Jayco feedback on Hummingbird and they have similar complaints. Overall I do like the floorplan and appliances and plumbing all seem good. Just the fit and finish on trailer construction is a bit lacking. My guess is that the baby boomers are retiring and rv manufacturers may be pushing their ability to assemble product with consistent quality results. As far as the lock on the front storage hatch..I am pushing in on door while unlocking and it still is a bit tricky. I read one person broke his key in lock..bad if you need to get in and since all my tools are in there it is really not a situation I would want to be in. Anybody try to get a locksmith out at Valley of Fire state park?? Water on floor could be refrigerator hatch but not sure at this point. Will document with dealer and if it happens again, even outside of warranty, I have a leg to stand on with Forest River. Bottom line here is I think owner upgrades on certain items in trailer are the norm with these products. Afterall the companies are trying to make profit and when you think about the complexity of the systems that are installed in these small trailers, it is amazing they turn a profit. I suspect they hire workers and pay them a marginal amount for their labor. Thanks for the informative feedback! Much appreciated
mjlrpod
Posted: 19 Nov 2017 at 10:10am |
Unfortunately JM, some of the workmanship on the pod is , well, piss poor. I had a similar issue with them cutting a hole to big, and out of round and only 3 screws actually screw into anything, One of them isnt even 100% enclosed in material. Some would say only 2 screws actually do anything. But its built inexpensively, and light. This doesnt excuse poor quality in workmanship in my opinion, but, if its only minor things that the dealer takes care of, I dont get to upset. It sounds like you are at least being treated well by the dealer, even though its a hassle to need to go to them. I hope you get everything resolved and have a great time from here on. I had 2 issues do to poor workmanship on my new pod. The dealer was great about fixing them, no hassle, no charge and everything has been good since.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
wooleeman
Posted: 18 Nov 2017 at 5:07pm |
I am new to the RV world also and use antifreeze. More importantly I found that using the pink stuff can help find leaks in the plumbing. Winterized this week for the first time and found the pink stuff in my shower. Looking into it further I found my bathroom sink trap had only been hand tightened. (I had found my kitchen trap loose earlier.) Can't hurt especially during your shake down period.
2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
Posted: 18 Nov 2017 at 4:51pm |
Antifreeze use is at owners discretion and comfort level. This will be our 6th year we have only used compressed air to blow out our lines. Line pressure is about 60 psi. I hook it up to the pigtail from the 3-way valve located below the kitchen sink. I always keep one line open when blowing out, takes about 1 minute to twice go through hot and cold at both sinks and at the commode. We are in northern Michigan where winter temps can hit -20 F or lower during our cold spell in January. I do use 16 ounces of rv antifreeze each year to dump into both traps for the sinks, the trap for the shower and some on top of the lid on the commode to keep the seal wet. You can do the math, I do use 1 gallon of RV antifreeze over an 8 year period. The one I am using now cost me 99 cents when I purchased it back in 2012.
