  New Posts New Posts RSS Feed: Water City
Topic ClosedWater City
HARLEYULTRA View Drop Down
Direct Link To This Post Topic: Water City
    Posted: 24 Nov 2017 at 6:37pm
Thanks Mark & Mike
I did all the above.It is 7:35pm & dark. Will check am. This is a new unit & 1st use. Thank You Bill
mcarter View Drop Down
Direct Link To This Post Posted: 24 Nov 2017 at 4:39pm
+1 - had same issue for over a year. Cycling appeared to fix but issue would return, replaced water pump and problem gone. BTW - inspected pump more than once and could not see anything wrong with check valve, I put a 1/2" NPT valve on fresh water drain to better see when it was happening. Also I do use a pressure regulator so pressure wasn't the issue.
mjlrpod View Drop Down
Direct Link To This Post Posted: 24 Nov 2017 at 1:09pm
No, it should not fill your tank when on city water. There is a check valve that gets stuck at times. Disconnect the city water, then cycle the water pump several times, on/off - on/off. That should unstick it.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 24 Nov 2017 at 12:37pm
When on City Water all good but potable tank keeps filling. Is this supposed to work this way.
