Forum Home Forum Home > General Camping > Cook'n With Gas
  New Posts New Posts RSS Feed: Convection Oven Conversion Guidelines
Topic ClosedConvection Oven Conversion Guidelines
rpodcamper.com View Drop Down
Direct Link To This Post Topic: Convection Oven Conversion Guidelines
    Posted: 17 Feb 2010 at 11:34pm
General Convection Oven Recipe Conversion Guidelines
There are three commonly accepted methods of converting recipes from conventional oven baking to convection oven baking.
  1. Bake at the same conventional oven temperature but for a shorter period of time.
  2. Bake for the same length of time as you would using a conventional oven but reduce the temperature by 25 degrees.
  3. Bake for a slightly shorter period of time and a reduced temperature.  This tends to be the most successful method for most ovens.
When Should Convection Cooking Be Used Rather Than Conventional Cooking
Foods cooked in a convection oven cook about 25% - 30% faster than a conventional oven as the hot air is forced around the food.  Foods tend to have less moisture loss and fewer nutrients are destroyed in the cooking process.
One of the most important factors when determining which cooking method is most appropriate for your food is the type of dish or pan you are cooking in.   If the cooking container blocks the flow of air around the food then there is no use in using convection cooking.
Convection Cooking Is Good For
  • Cookie sheets
  • Shallow pans
Convential Cooking Is Good For
  • Covered casseroles, pans or dishes
  • Deep roasting pans
More Convection Cooking Tips
Manufacturer Guidelines
Follow the recommendations from the manufacturer of the oven. Your oven typically shipped with a user guide. It is a good idea to familiarized yourself with the specifics for your own oven. If you don't have a user manual then try contacting the manufacture to obtain a copy. Many provide printable copies online.
Air Circulation
Air circulation is important. Don't cover racks with foil. Allow 1 to 1 1/2 inches around pans (also above and below pans for multi-rack baking).
Use Proper Pans
For maximum browning, use pans with low sides, and rimless cookie sheets. Many ovens come with special pans and racks that lift roasts so air flows all around. If possible, place the long sides of the pan parallel to the oven door.
Roasting Guidelines
Roast meats and poultry
Preheating is not necessary. Place meats on a rack in the roasting pan for better browning. Roasting time may be 20 to 30 percent less than in a conventional oven if temperatures aren't reduced. Some ovens offer a special roasting mode that provides top and/or bottom browning or an initial surge in heat in addition to the fan. These modes make it easy to get optimum results in a shorter time.
Small Roasts or Unstuffed Poultry
Do not reduce oven temperatures for small pieces, skinny roasts, or unstuffed poultry. In our tests, we roasted a 3 1/2-pound chicken at 375 |degrees~. In about an hour, about 20 percent less time than for conventional cooking, it was beautifully browned, with succulent flesh.
Dense Roasts & Stuffed Turkeys
For large, dense roasts and big stuffed turkeys, you may need to reduce the temperature 25 |degrees~ during part or all of the roasting time. When you lower the temperature, the meat may be juicier and shrink less, but it will take longer to cook.
Convection Cooking Charts
Method 1:  Reduce temp by 25 to 30 degrees and bake per conventional recipe time
Conventional Oven Temp
Convection
Less 25F
Convection
Less 30F
225
200
195
250
225
220
275
250
245
300
275
270
325
300
295
350
325
320
375
350
345
400
375
370
425
400
395
450
425
420
475
450
445
500
475
470
525
500
495
550
525
520
Method 2:  Bake at conventional oven temperature but reduce cooking time by 25%-30% less
Conventional Baking Time In minutes
25% Less Time
30% Less Time
10
8
7
15
11
10.5
20
15
14
25
19
17.5
30
23
21
35
26
24.5
40
30
28
45
34
31.5
50
38
35
55
41
38.5
60
45
42
65
49
45.5
70
53
49
75
56
52.5
80
60
56
85
64
59.5
90
68
63
95
71
66.5
100
75
70
105
79
73.5
110
83
77
115
86
80.5
120
90
84
125
94
87.5
130
98
91
135
101
94.5
140
105
98
145
109
101.5
150
113
105
