  New Posts New Posts RSS Feed: Fresh Water Drain Valve
Topic ClosedFresh Water Drain Valve
mcarter View Drop Down
Direct Link To This Post Topic: Fresh Water Drain Valve
    Posted: 24 Feb 2018 at 5:19pm
I put a valve drain on mine, no more cap. It extends down about 2 inches, works fine.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 4:28pm
Originally posted by 01tundra
Didn't realize the pods were different.  Couldn't you add a threaded brass elbow in place of the plug and convert to barb fitting, then screw a valve bracket to the frame like ours has?
Then they could be damaged by thrown road debris?
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
01tundra View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 1:31pm
Direct Link To This Post Posted: 24 Feb 2018 at 1:29pm
We do the same as Wepod, open up the lower point drains and ho water tank then drive the back roads for a few minutes. Drains it all!
Direct Link To This Post Posted: 24 Feb 2018 at 12:23pm
One can push up on the bottom of the tank and get more to drain. However, that is far from an ideal way to get the water out. If the bottom of the tank were supported so that it did not sag, then I don't think it would be so much of an issue.
Wepod View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 12:20pm
I found the only way to get all the water out of the tank is to leave the cap off and drive about 10mi.
ron_whitt View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 12:16pm
What StephenH just said...
Ron & Shirley
2020 Tacoma
2012 177 rpod
Direct Link To This Post Posted: 24 Feb 2018 at 12:01pm
Originally posted by mjlrpod
Pods don't have this type drain. Ours is just a plug. My only wish about the drain plug is, I wish it was at the lowest point of the tank. One tends to think a tank drain will drain ALL of the water out of the tank. Maybe its me.
It isn't just you.Smile
mjlrpod View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 11:59am
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 24 Feb 2018 at 8:11am
Nice job!!
